97 f250 been sitting for 3 years - PowerStrokeNation : Ford Powerstroke Diesel Forum
 9Likes
post #1 of 28 (permalink) Old 04-19-2019, 02:43 PM Thread Starter
Iím a new member I bought a 1997 Ford F-250 with the 7.3 for $800 itís been sitting for 3 years without being started. I was there yesterday the truck is 45 minutes from me but I changed the oil put 2 new batteries in it and turned the key just to see if I can get it to move out if itís grave. It didnít start I know I should drain the old fuel out and put fresh fuel in. It started to rain pretty hard so I went home itís raining today but will stop soon I want to know what I should do to get it to where I can drive it 45 mins home to work on it in my garage. Only progress Iíve made is air up the tires change the oil put new batteries in it sounds like it wants to start but it just wonít it just smokes
eric.wasilko is offline
post #2 of 28 (permalink) Old 04-19-2019, 02:58 PM
Native Texan
masakimm's Avatar
Garage
Re: 97 f250 been sitting for 3 years
If its trying and smoking probably just needs some clean fuel. what's the temps there.
Give it to Mikey. He won't eat it he hates everything. Hey Mikey!! He Likes It.
Upgrades:
masakimm is offline
post #3 of 28 (permalink) Old 04-19-2019, 03:03 PM Thread Starter
It was 75 when I was messing with it yesterday today itís only about 50 because of the rain Middle Tennessee
post #4 of 28 (permalink) Old 04-19-2019, 04:29 PM
Native Texan
masakimm's Avatar
Garage
Well temp should have not played a part in not starting is ur wait to start light coming on is ur rpm gauge moving.
Upgrades:
masakimm is offline
post #5 of 28 (permalink) Old 04-19-2019, 05:32 PM Thread Starter
Yea light comes on and rpms move
post #6 of 28 (permalink) Old 04-19-2019, 11:33 PM
matthewd11's Avatar
Drain the fuel and put fresh fuel in with some treatment.
matthewd11 is offline
post #7 of 28 (permalink) Old 04-19-2019, 11:36 PM
Native Texan
masakimm's Avatar
Garage
Check the Filter see if its getting fuel pump may not be pumping enough fuel to start the truck. use a tire gauge and check the fuel pressure while cranking should be above 50 to start.
Upgrades:
masakimm is offline
post #8 of 28 (permalink) Old 04-20-2019, 12:11 AM Thread Starter
Thank ya I was at Walmart today and bought a bunch of stuff for it I got some of that Lucas fuel injector stuff to put in it. Whatís the easiest way to drain the tanks? I have a cheap siphon thing but couldnít find a big one that actually works good.
post #9 of 28 (permalink) Old 04-20-2019, 12:15 AM
HilhavenFarm's Avatar
https://shop.advanceautoparts.com/p/...E&gclsrc=aw.ds
I bought one of these @ Harbor Freight and modified hoses. It is slow but pumped out 15 gallons of old fuel.
1996 F350 XL Crew Cab LB 4x4 3:55
Former Ft. Bragg/Pope AFB Truck
DieselSite Coolant Filter
Riff Raff Diesel Turbo & Y Boot Kit
Riff Raff Diesel HPX
Mile Marker 449SS Manual Hubs
1987 F250 XLT Lariat LB 2WD 4:10
6.9/7.3 IDI Swap-SOLD
2010 John Deere 5055D
1974 Deutz 5506
2950 hours-"The Tank"
HilhavenFarm is offline
post #10 of 28 (permalink) Old 04-20-2019, 12:17 AM Thread Starter
Yea thatís the exact One I have I canít get the darn thing to work
Similar Threads
03 f350 7.3 been sitting for 6 years 037.3rider 7.3L Power Stroke Technical Info 5 06-08-2016 12:52 PM
Injectors been sitting for 5 years Powerstroke` 1994-1997 Power Stroke Technical Info 5 10-22-2015 09:54 PM
2005 F250 That's Been Sitting finefirewood 6.0L Power Stroke Technical Info 5 06-11-2015 03:03 AM
Just bought a truck, been sitting for 3 years ejj005 1994-1997 Power Stroke Technical Info 31 05-28-2013 02:06 PM
Starting an engine after sitting 6 years, any tips???? joedaddy 7.3L Power Stroke Technical Info 177 05-14-2011 07:10 PM
