Transmission solutions for a "heavy duty" f350 - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Sbluke55
post #1 of 4 (permalink) Old 04-16-2019, 04:32 PM Thread Starter
Powertoker's Avatar
I purchased a truck that is a "heavy Duty" model, 8 Lug with a 12' Bed.
When I purchased the truck, previous owner said Tranny had been rebuilt(but it felt week when I bought it)
I have a 10k Bed on it, and the weight has just COOKED this tranny.. I feel like I need to go to like 4:88 gear ratio, I believe Im at 410.
I should probably have the tranny rebuilt with a inter cooler..
Does anyone have some recommendations to keep my budget low?
I havent rebuilt a transmission before, and i'm not sure I want to do this. I might just want to sell it, I have too many trucks right now.
Good engine, 98k miles, new injectors, T500 HPOP, Turbo Upgrades, Up-pipe upgrades.. I know If i sell it im going to loose a lot that I put in it lol
Thanks..
Powertoker is offline
post #2 of 4 (permalink) Old 04-16-2019, 04:41 PM
Bugman's Avatar
Re: Transmission solutions for a "heavy duty" f350
Low budget and good do not go together.
Also those that have tried to rebuild a transmission usually have problems with it withing 6 months or so, this is something that needs to be farmed out if you don't know what you are doing.
All I can say if you want one to last check out John Woods Transmission if you are on the west coast and BTS if on the east.
Other than that if I was to going to have a local shop do it I would check to see if there is a ARTA certified shop in my area.
Bugman is offline
post #3 of 4 (permalink) Old 04-16-2019, 04:49 PM
Moderator
Sbluke55's Avatar
I would recommend diesel site for the trans and upgrade to a 6.0 trans cooler.
masakimm likes this.
01 f-250, Standard
Sbluke55 is offline
post #4 of 4 (permalink) Old 04-16-2019, 06:04 PM
longjonsilver's Avatar
Thanks..
Where are you located?
longjonsilver is offline
Similar Threads
what heavy duty drop hitch for big tires and up to 10,000# tow? Dave R Towing and Hauling - The Work Horse Forum 14 11-25-2009 11:53 AM
Heavy duty Steering? theham1105 7.3L Power Stroke Technical Info 25 03-17-2009 06:57 PM
Heavy duty steering box? 707.3 7.3L Power Stroke Technical Info 5 03-05-2009 11:31 PM
Heavy Duty Alternator? imelmo 7.3L Power Stroke - Aftermarket & Performance 12 09-05-2007 04:18 AM
