1996 low oil pressure - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 04-13-2019, 10:55 PM Thread Starter
I just completely rebuilt my motor, new lpop, hpop, pistons, cam. Pretty much everything in new. I installed an auto meter low oil pressure gauge on top of the hpop where the factory oil pressure switch was located. But I'm only reading about 2 psi at idle. When I'm driving it goes to about 30 or so. It runs real smooth at idle and driving. Do I have an issue, or should I mount the pressure gauge some where better?
Tom63bg is offline
post #2 of 2 (permalink) Old 04-15-2019, 02:22 AM
longjonsilver's Avatar
Re: 1996 low oil pressure
Make sure the bypass disc in the oil filter housing isnít stuck open or fell out . They are bad for becoming un-staked in the housing .
Unscrew the oil filter and check it out
longjonsilver is offline
Similar Threads
High pressure pump loosing prime. Low pressure oil pump cover came loose... Goneracin 7.3L Power Stroke Technical Info 10 12-20-2017 12:54 PM
Low fuel pressure or oil pressure? jtgf250 7.3L Power Stroke Technical Info 2 03-21-2013 05:06 PM
1996 7.3 low oil pressure and low on power czangli7 [7.3L - Technical Info] 1 01-19-2013 10:48 PM
low pressure oil low at high rpms Twisted Addiction 7.3L Power Stroke - Aftermarket & Performance 26 02-28-2011 06:40 PM
High "low pressure oil" Pressure NorCalDiesel 7.3L Power Stroke Technical Info 37 07-19-2008 02:31 PM
