Negative camber issue - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 04-13-2019, 03:48 PM Thread Starter
Crusty7.3powerstroke97's Avatar
I have 97 f350 with f450 springs in the front and lift blocks in the rear on 35s. I'm having an issue with negative camber after doing ball joints and tie rods. I can't seem to figure out how to fix the issue and the front axle doesn't look bent or anything. What would be the best way to fix this?
Crusty7.3powerstroke97 is offline
post #2 of 7 (permalink) Old 04-13-2019, 03:55 PM
PSN intsigator
heavydoc's Avatar
Re: Negative camber issue
Take it to an alignment shop and have them look at it
96 F350 rclb drw 2wd psd (built not bought)
01 Excursion Limited 4wd psd (the wifes ride)
02 F350 cclb drw 4wd psd (the land yacht)
heavydoc is online now
post #3 of 7 (permalink) Old 04-13-2019, 04:21 PM Thread Starter
I have already aligned the truck myself at work. I was trying to figure out a way to pull it all back together.
post #4 of 7 (permalink) Old 04-13-2019, 05:21 PM
Master BS'er
jamiesaun's Avatar
You did it yourself at work? As in, on an alignment rack?
How negative are we talking here? Hundredths of a degree, tenths, half a degree? Or does it just look tilted in a little bit?
If the camber really is negative on a solid axle truck then something is bent, or installed wrong, depending on how negative we're talking about here.
Maybe we need a picture.
Brother James
Ps...Im pretty frickin awesome!
jamiesaun is offline
post #5 of 7 (permalink) Old 04-13-2019, 05:30 PM
Master BS'er
jamiesaun's Avatar
Speaking of negative camber, check this one out from a couple days ago. They actually drove it there like that, Lol! Didn't even know that was possible.
They must have just watched Fast and Furious or something gay like that.
Sent from my SM-G950U using Tapatalk
Brother James
post #6 of 7 (permalink) Old 04-13-2019, 05:44 PM Thread Starter
Yeah I put it on the alignment rack and it's noticeable when looking at it but it's more than likely right around a degree out. It was like that before I did ball joints cause it wore out the inside of the tires more than the outside.
post #7 of 7 (permalink) Old 04-13-2019, 05:56 PM
Master BS'er
jamiesaun's Avatar
A degree is quite a bit. Maybe it's the wheel or something. Swap the wheels and see if it follows the wheel around.
Or you could do a wheel off alignment check
Brother James
Similar Threads
Negative Offset Wheels, -40 or more, ideas??? cartmanea 1999-2010 Super Duty General Aftermarket 9 08-10-2012 06:23 PM
96 f250 negative arch springs worn? gtmustang00 1994-1997 General Aftermarket 10 01-13-2010 02:40 PM
Negative Camber while backing up? Coltaine 1994-1997 General Aftermarket 13 10-26-2009 06:41 PM
Negative boost pressure??? FordCowboy 7.3L Power Stroke Technical Info 23 07-24-2009 12:56 AM
Anything negative with stacks? fireboltjoel03 1994-1997 OBS Power Stroke - Aftermarket & Performance 31 11-12-2008 04:28 AM
