95 running a month ago died help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 04-12-2019, 02:29 PM Thread Starter
I just had the engine overhauled and everything is new except the injectors and turbo. Smoked horrible after rebuild. Decided I would run my super chip on hot tune and see if it would straighten out or blow. Now it just cranks and no thought of firing off any thoughts before I start parting it out.
95f350flatbed is offline
post #2 of 5 (permalink) Old 04-12-2019, 03:46 PM
Moderator
Sbluke55's Avatar
Re: 95 running a month ago died help
Do you have the wait to start light?
Where are you at?
01 f-250, Standard
Sbluke55 is offline
post #3 of 5 (permalink) Old 04-12-2019, 03:50 PM Thread Starter
Yes the wait to start light cycles as it should and Carroll county Maryland
post #4 of 5 (permalink) Old 04-12-2019, 04:44 PM
Native Texan
masakimm's Avatar
Garage
Did the oring get replaced with good ones on the injectors.
Give it to Mikey. He won't eat it he hates everything. Hey Mikey!! He Likes It.
Upgrades:
masakimm is online now
post #5 of 5 (permalink) Old 04-12-2019, 04:58 PM Thread Starter
Orings were replaced with OEM ones from for every thing was OEM that was put in
Similar Threads
need 6.4l help bad competeing in less than a month and trucks down!!!!! plz help rhoade667 6.4L Power Stroke - Technical Info 0 09-09-2012 07:42 PM
Two years ago this month, there were 24 left. Now they are all gone cowboy_dan General Questions & Discussion 0 08-01-2009 03:53 PM
17 years ago today superf350 General Questions & Discussion 24 10-28-2008 03:07 AM
Found that Gauge pod I was looking for a month ago... CSIPSD 1999-2010 Super Duty General Aftermarket 18 02-06-2008 11:04 PM
