1996 7.3 just a question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 04-11-2019, 07:31 PM Thread Starter
New here trying to figure out a good balance for my truck don’t tow much but want the ability too if needed . Have efuel,intercooler,intake,3”dp and ts chip . Looking at a t4 setup,injectors and turbo . Is there a tried and true set up ? Would like a mid 400 rwp
Sureshift is offline
post #2 of 3 (permalink) Old 04-11-2019, 08:44 PM
Moderator
Sbluke55's Avatar
Re: 1996 7.3 just a question
160/30’s and an sxe 364.5.
01 f-250, Standard
Sbluke55 is offline
post #3 of 3 (permalink) Old 04-11-2019, 11:10 PM
Patrick Feeley's Avatar
If you have an E4OD tranny, don't forget about some love for it too! They don't like 400+ HP in stock form. Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3” DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
Similar Threads
1996 7.3 f250 won?t crank, just changed fuel filter, water in fuel light on Mech3ngr 1994-1997 Power Stroke Technical Info 31 10-31-2017 02:59 PM
JUST FINISHED THE ZF5 CONVERSION! ON 1996 350 PSD kevin24 Engine & Transmission Conversion 6 03-18-2013 10:03 AM
Just bought a 1996 F-150 pappy19 Gasoline Engine Forum 4 09-18-2009 03:36 AM
Is it just me or is this Sara Varone just freakin hot Phatbulldog General Questions & Discussion 12 02-17-2008 04:24 AM
