Quick Turbo Lesson please!!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 03-24-2010, 04:42 AM Thread Starter
ETaylor0056's Avatar
Well Iv got a hunch that my turbo is about to go KA-BOOM and am needing a little lesson on what kind of turbos to be looking for and the differences in them. Iv seen some on ebay for some good prises but am woundering what the difference is between a 1.00 1.10 and 1.15, housings and compressior wheel?. Everybody claims to have this and that but from experience what should i get for a truck that is driven everyday, pulls a trailor everyonce and awhile and in the future going to have a big chip on it. Iv got a new down pipe and stright lines to.????????????????? O yea and around 650 bucks to if possible.
1999 Ford F.250 4X4 Cortex
1976 Ford F.100 step-side 347 STROKER (Fast)
1963 Ford F.100 4X4 (ORIGINAL 223CI)
ETaylor0056 is offline
post #2 of 18 (permalink) Old 03-24-2010, 05:00 AM
your mom
RMPowerstroke's Avatar
Re: Quick Turbo Lesson please!!!
well lets start here what do you mean by big chip . what kind of tunes and tuner where do you live elivation plays a key part. are you planing on ever puting stage 1s in it. and personal pref the turbos on e-bay like from rons turbo are not worth ur time. also in a obs i dont think a wicked wells worth it
f350 king ranch dubed. ol ranchero thanks to wayne
04 cc/lb 9inch lift C-6 built converter custom revs manual valve body r servo. powered by 12v cummins p-pump 4k gvs custom lasered dlv pump work, 5x16 sticks, singler charger for now, airdog150, its on meth lots of custom junk. hids road armor bumper and im truck broke
06 f-150
RMPowerstroke is offline
post #3 of 18 (permalink) Old 03-24-2010, 06:38 AM
What makes you think yours is going "Kaboom" ? How the fins look? what kine boost do you see?
If your keeping stock injectors And just getting a chip, A Stock turbo should do you fine
96'
F250 Some stuff
Bamboo is offline
post #4 of 18 (permalink) Old 03-24-2010, 06:45 AM
What else?
smokyred's Avatar
I'd pull the intake and check the turbo for play before you go dropping money on another one. A little side to side play is normal, any in and out play is not. Also the wheel should not contact the housing.
You don't really have to worry about hurting a stock turbo with just a chip, the most you'll make is about 260hp at the rear wheels. The OBS trucks have too small of injectors to do much. Now if you get injectors that changes, I killed a few stockers back in the day with stage II's.
As for Ron, other members as well as myself have bought turbo rebuild kits and compresor wheels from him, and he was great to deal with. I would expect the same from his complete turbos.
Dave
smokyred is offline
post #5 of 18 (permalink) Old 03-24-2010, 07:00 PM Thread Starter
Holy Crap whats that piston out of in the picture??? And what i mean by Big Chip is like a Tony Wildman 6 pos. or a TS performance 6 pos. one or the other in the Future. I live in the Hills and hallars of western Ky and dont know what the elivation is. I really dont know about putting new injectors in it yet probly not though. Im trying to save all the money i can for college.
post #6 of 18 (permalink) Old 03-24-2010, 07:08 PM Thread Starter
Well dont have a boost gauge yet but am working on it. The main reason i think somthing is wrong is when i bought the truck there was a metal wire tie riged up from a linkage on the turbo on the exhaulst side to the motor hitch. (That place were you can hook your motor hoist to too pull the motor) Any ways when i cut the wire tie. i started having this awfull sound form the exhaulst and when it makes the sound it boggs down my motor. I aint got a clue what it is but i made another wire tie and fixed it again. WHATS THAT GOT TO DO WITH IT??????????
post #7 of 18 (permalink) Old 03-24-2010, 07:14 PM
oil burner
tughill283's Avatar
sounds like your exhaust backpressure valve was rigged open somehow
96 f250, ZF5,160cc,
300k miles
96 f350 plow truck
tughill283 is offline
post #8 of 18 (permalink) Old 03-24-2010, 07:41 PM Thread Starter
Why would it try shuting on me while the truck is just running tho? And is that a stack through your hood? whats that sound like?
post #9 of 18 (permalink) Old 03-24-2010, 07:46 PM
Strokin'
I unhooked mine. some guys just delete the EBPV.
94' F-250 PSD, Reg. cab, 4x4, ZF-5, K&N, 3" DP, 5" Exhaust.
93' F-250 SCLB, 4x4, Gas.
88' F-350 460 Wrecker. Lots of LED's.
The Bank doesn't own my trucks.
jakeloney is offline
post #10 of 18 (permalink) Old 03-24-2010, 09:11 PM
like stated that your ebpv your turbo is fine, its there to help warm it when the oil temp is below a certin point.
02 f250
countryboyrob is offline
