1996 f250 ujoints??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
 3Likes
  • 1 Post By 78-79fordman
  • 1 Post By tjctransport
  • 1 Post By m j
post #1 of 8 (permalink) Old 04-11-2019, 01:57 AM Thread Starter
A dawg
I sheered the rear ujoint off the driveshaft of my 1996 f250 powerstroke and was looking to replace the front and rear of the driveshaft with stronger ujoints as preventive maintenance. My mechanic said the front and rear driveshaft ujoints are different sizes but after searching online for hours I cannot find anything on that. Any help or suggestions for quality ujoints that can handle 800lbs of torque to 35s???
Alex Maher is offline
post #2 of 8 (permalink) Old 04-11-2019, 02:37 AM
Spicer going to be about as good as I know
Alex Maher likes this.
78-79fordman is offline
post #3 of 8 (permalink) Old 04-11-2019, 03:01 AM Thread Starter
A dawg
Re: 1996 f250 ujoints???
Thanks for the reply, do you know anything about the size differences??
post #4 of 8 (permalink) Old 04-11-2019, 09:44 AM
alleged moderator
tjctransport's Avatar
spicer 1410 universal for both front and rear on the F250-F350 4X4 one piece rear drive shaft.
tom
tjctransport is offline
post #5 of 8 (permalink) Old 04-12-2019, 01:14 AM
Wouldn’t a 96 have 1330’s on the front driveshaft and 1350’s on the rear?
1995 Crewcab XLT 4x4 7.3, E4OD, 3.55, TS 6 chip, RiffRaff air filter.
Whoknows is offline
post #6 of 8 (permalink) Old 04-12-2019, 04:31 AM
m j
m j's Avatar
he only asked about the rear shaft.
power didnt break those ujoints
Sbluke55 likes this.
1997 F250 rclb 4x4,Comp910s,SRP1.1,Irate T4 s468,FullForce 350/200,efuel A1000 5/8" drawstraw,DI fuel fittings,D60f Detroit,Grizzly10.25,windowed 7.3 Oct 9/14
rebuild .010 riffraff cut pistons,swamps fire ring kit,Girdle,high-filled block,Manley rods,SBC dualdisc,ATI dampner,MorelLifters,MantonPushrods,ColtCam,
m j is offline
post #7 of 8 (permalink) Old 04-12-2019, 08:53 PM
alleged moderator
not according to all the parts links i saw.
tom
post #8 of 8 (permalink) Old 04-25-2019, 03:11 AM Thread Starter
A dawg
can confirm the ujoints are different sizes. the ujoint connecting the rear driveshaft to the tranny is much larger than the ujoint connecting it to the diff
Similar Threads
ujoints yoke mjones Suspension and Drivetrain 1 05-28-2011 01:44 AM
2000 F350 cclb rear driveshaft ujoints and carrier bearing JAKE 7.3L Power Stroke Technical Info 5 12-27-2010 06:31 PM
1996 f250 front half left half shaft needed cumminskiller697 1994-1997 General Aftermarket 0 02-06-2009 07:09 PM
