AC system rebuild - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-07-2019, 09:00 PM Thread Starter
TexasJ's Avatar
AC system rebuild
Hi guys, I am replacing the ac compressor, condensor, dryer, evaporator, and all Orings lines and hoses on my 96 F250. After I do this I plan on driving it to my mechanic to have him charge the system properly. My question is: will it damage any of the new components if I install everything and then drive it without any freon or pag oil in the lines? If so, can this be avoided by disconnecting the electrical pigtail from the compressor? Or perhaps by leaving one of the hoses disconnected for air to escape? I don't want to risk putting all these new parts in only to have them get destroyed by driving 5 miles without fluid in the system.
TexasJ is offline
post #2 of 4 (permalink) Old 04-07-2019, 09:17 PM
Native Texan
masakimm's Avatar
Garage
Re: AC system rebuild
If the system is working properly then the comp can not engage with out a charge in it. there are switches that prevent the compressor from being engaged.
Upgrades:
masakimm is online now
post #3 of 4 (permalink) Old 04-07-2019, 09:40 PM Thread Starter
TexasJ's Avatar
Thank you!
TexasJ is offline
post #4 of 4 (permalink) Old 04-08-2019, 12:33 AM
roll on u will be fine
78-79fordman is offline
Similar Threads
Ac to max ac fan speed difference? Varro 7.3L Power Stroke Technical Info 10 07-18-2015 02:13 AM
AC full but blows warm on max ac bdemutis General Questions & Discussion 11 07-04-2015 10:48 AM
Gas AC vs. Diesel non-AC wiring Nor'Easter 1994-1997 Power Stroke Technical Info 0 07-21-2013 11:29 PM
Max AC fan speed 1&2 not working regular AC working clydesdale 7.3L Power Stroke Technical Info 0 03-24-2013 06:32 PM
Ac system Bigtimearcher 7.3L Power Stroke Technical Info 6 10-02-2007 03:26 AM
