CCSB ZF5 4x4 driveshaft length - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 1 (permalink) Old 04-04-2019, 05:35 PM Thread Starter
Tristanmoore001's Avatar
Hey guys, I had my transmission and rear driveshaft blow up a few weeks back, and am in need of some help from the CCSB ZF5 4x4 guys. I just ordered the new transmission and (being as impatient as i am) was wondering if any of you guys out there could tell me your rear driveshaft length?
My truck is a CCSB, with a new zfs547 on the way, 4x4, and has a 4.5 inch lift. The other thing is I'm replacing the one piece driveshaft that was back there, so I would need to know the measurements from the flange on the transfer case to the yoke on the differential.
If anyone has those lengths it would really be appreciated. That way I can order the driveshaft so I can assemble everything at once instead of waiting an additional 3 or 4 days while a shop builds it once I give them the length from my truck with the new trans and transfer case back in it.
97 4x4 F350 XLT OBS Powerstroke CCSB- ZF-5 manual trans, 6637 cold air intake, TS6 chip, straight piped 4 inch turboback pretire side exit, 4 pillar gauge w/ diff temp, EGT, boost, and HPOP pressure, ATS diff cover, dual alpine 10'' subs w/ alpine component speakers, B code rear springs
Tristanmoore001 is offline
Similar Threads
Driveshaft length / play Rollncoal7.3 1994-1997 General Aftermarket 12 11-21-2012 11:51 PM
Driveshaft length 02POWERSTROKE7.3 Suspension and Drivetrain 0 10-03-2012 01:41 AM
driveshaft length for 10'' lift? Shwizzle 7.3L Power Stroke - Aftermarket & Performance 0 02-21-2012 09:57 PM
'97 CC SB D60 4x4 ZF-5 Rear Driveshaft length?? JCart 1994-1997 Power Stroke Technical Info 5 04-14-2011 09:05 AM
driveshaft length ? Cat_Rebel 1994-1997 General Aftermarket 6 09-02-2008 01:15 PM
