Electrical fun - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Whoknows
post #1 of 3 (permalink) Old 03-27-2019, 03:10 AM Thread Starter
College Student
Electrical fun
I replaced my alternator today with 2 brand new ones from O'reillys and still have problems.
The voltage gauge for the past month would wave ranging from 12volts to 16 volts while the battery light would flicker when it would idle. When driving it would stop and stay consistent at around 14v like normal. But this morning on my way to classes, it stopped doing this and the voltage needle would sit around 12volts and the battery light is staying on.
I looked up what would cause this and I read that it is the voltage regulator. So I replaced the alternator and nothing changed. I drove it for a while and stopped ant another O'Riellys and had them test the alternator. The batteries tested fine, but the voltage regulator test would fall. So I pulled it and had them bench test it. But after testing it, the results would pass. So I tried putting in another one and it did the same thing. Pass the bench test, but fail the test in the pickup. I had them test my original one and it would test fine on the bench as well.
I am at a loss as for what it could be. I don't really want to be driving down the road and literally run out of power. This is my daily driver and I dong have any other vehicles to use is also another problem of mine.
Any Ideas?
95 Auto. 4.10 gears. SCLB. Stock besides Baby Swamps Injectors and TS-6 chip with swamps tunes. AFE MaxFlow. Glowshift trans, pyro, and boost. 6.0 IC KC TP38R. Converted EBPV to exhaust brake.
Cumminsdurastroke is offline
post #2 of 3 (permalink) Old 03-27-2019, 03:41 AM
could still be bad battery . or battery cables .
I had a bad vacuum pump cause the same problem last year on my 97 .
78-79fordman is offline
post #3 of 3 (permalink) Old 03-27-2019, 08:05 AM
Re: Electrical fun
A bad ground or corroded cable can make some weird stuff happen. A lot of times you canít tell just by looking at it either. I hate dealing with electrical issues but Iíd start looking there.
JCart likes this.
1995 Crewcab XLT 4x4 7.3, E4OD, 3.55, TS 6 chip, RiffRaff air filter.
Whoknows is offline
Similar Threads
Electrical, I HATE ELECTRICAL! strokin'patty 7.3L Power Stroke Technical Info 5 11-09-2012 07:18 PM
FUN, FUN, FUN!!!!!!!!!!!!!!! cshsrh 6.0L Power Stroke - Aftermarket & Performance 5 07-01-2009 04:50 AM
NorCal: Fun Ford Sunday 9/9/07 HighOn20s National Events 3 09-09-2007 03:36 AM
