Slight miss , sometimes... - Page 10 - PowerStrokeNation : Ford Powerstroke Diesel Forum
 3Likes
post #91 of 169 (permalink) Old 04-19-2019, 06:10 PM Thread Starter
longjonsilver's Avatar
Re: Slight miss , sometimes...
Originally Posted by heavydoc View Post
You are welcome
HPOP is in , truck runs but the bottom line on the fuel bowl is leaking fuel . I picked up some multi fuel and bio fuel line at Napa . My plan is to cut one of the top new blue fuel lines down to fit the bottom port and put some of this Napa hose on the top so if there is any issue I can get at the Napa line easily.
longjonsilver is offline
post #92 of 169 (permalink) Old 04-19-2019, 06:47 PM
PSN intsigator
heavydoc's Avatar
But is she running better
96 F350 rclb drw 2wd psd (built not bought)
01 Excursion Limited 4wd psd (the wifes ride)
02 F350 cclb drw 4wd psd (the land yacht)
heavydoc is offline
post #93 of 169 (permalink) Old 04-19-2019, 06:55 PM Thread Starter
I havenít driven it yet , it didnít take much to get it to start , of course I primed the HPOP reservoir so it cranked very minimal. It sounds quieter.
Weíve been inundated with torrential downpours since 5:30 this morning , lots of flooding and creeks cresting .
Our rain meter showed over 5Ē
post #94 of 169 (permalink) Old 04-19-2019, 08:10 PM
PSN intsigator
heavydoc's Avatar
I know what you mean I was working in Franklin and got maybe that much, I did almost quit when I was done though
heavydoc is offline
post #95 of 169 (permalink) Old 04-19-2019, 09:28 PM Thread Starter
Well the truck runs the exact same , still only making 2475 psi . I seriously doubt both pumps make the same identical pressure . Next Iím going to do the IPC and a new pigtail as itís oil soaked ....... lol
post #96 of 169 (permalink) Old 04-19-2019, 09:30 PM
PSN intsigator
heavydoc's Avatar
Are you reading that with a computer or a gauge?
heavydoc is offline
post #97 of 169 (permalink) Old 04-19-2019, 09:39 PM Thread Starter
Scan tool . Iím thinking regardless Iíll need a icp , itís leaking so itís shot . I need to make up a gauge and hose assembly to see actual numbers not what the computer calculates them to be .
post #98 of 169 (permalink) Old 04-19-2019, 09:43 PM
PSN intsigator
heavydoc's Avatar
I believe they are just -6 oring boss plugs
heavydoc is offline
post #99 of 169 (permalink) Old 04-19-2019, 09:44 PM Thread Starter
Thatís what it looks to be
post #100 of 169 (permalink) Old 04-20-2019, 03:15 AM
Native Texan
masakimm's Avatar
Garage
Hey just look at the bright side. Could be driving a beat down broken Hyundai Elantra.
Explosive Diarrhea not ur friend but a great weight loss tool.
Upgrades:
masakimm is online now
Similar Threads
Balance fault and slight miss sometimes 97obs_stroker 7.3L Power Stroke Technical Info 0 02-20-2019 06:48 AM
Sometimes grey, sometimes black? BeaveF250 7.3L Power Stroke Technical Info 1 11-18-2011 01:37 AM
Sometimes black smoke sometimes greyish? The 250 7.3L Power Stroke Technical Info 2 10-12-2011 08:46 PM
Sometimes won't turn over, sometimes will ezeggs 1994-1997 Power Stroke Technical Info 11 02-20-2010 12:30 AM
Sometimes start and sometimes no start?? dirt devil 7.3L Power Stroke Technical Info 1 10-14-2008 11:09 PM
