Baro Sensor - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 03-19-2019, 01:21 AM Thread Starter
Blue-Truck-Nut97's Avatar
Baro Sensor
Hey guys. Was trying out forscan and stumbled on something confusing.
I have had no CEL, and no driveability issues. 1997 F-250 7.3, E40D.
While checking codes I came up with a P0236. (Map out of range). So off to the PID's I go. Here is what I found.
KOEO-
MAP 81.5 kPa
MAP 102Hz
BARO 29.21 kPa
EBP 84.4kPa
Quick conversions tell me the map and exhaust pressure readings are real close to correct for my altitude, but the baro seems really low.
Am I on the right track? Seems like I'm in the market for a new baro sensor.
Seemed strange to me because I've had no problems, runs good, pulls good, no smoke, MPG's dropped a bit but I attribute that to winter warm ups. I cleared the code and it hasn't come back, but I haven't worked the truck, just cruising back and forth from the house.
Any ideas?
Also, upon finding the initial code, I checked the map sensor line, connection, and checked for manifold pressure leaks to be safe.
Blue-Truck-Nut97 is offline
post #2 of 17 (permalink) Old 03-19-2019, 01:46 AM
Bugman's Avatar
Re: Baro Sensor
The barometric pressure will fluctuate depending on if you are in a high or low pressure zone or if the pressures are raising or going down. If I remember right you said that you were around 6000' which would put the baro pressure at 81.22 kPa but if there is a low pressure area such as a storm where you are at it will be lower. That 81.22 kPa is just where they start measuring it for your altitude.
A good way to watch the pressure is to just watch the TV news and weather for your area. I am not sure if they still do it but they used to show the barometric pressure as a gauge for a weather change.
Now that I have you totally confused I wouldn't worry about it as long as the glow plug system is working alright. The baro sensor and the EOT is what tells them to come on and for how long.
I just looked at what the pressure was in my town on The Weather Channel and it shows 30.12 inches which is 103.1 kPa and if you look at the chart I should be 500' below sea level while I am sitting at +6500'
Bugman is offline
post #3 of 17 (permalink) Old 03-19-2019, 01:57 AM Thread Starter
Re: Baro Sensor
Thanks! I like the stuff that doesn't need worried about.
I have a barometric pressure app, so that's what I was comparing it to. It also has an altimeter, your memory is great!
post #4 of 17 (permalink) Old 03-19-2019, 01:59 AM Thread Starter
Re: Baro Sensor
Could the baro also have anything to do with the MAP out of range code?
post #5 of 17 (permalink) Old 03-19-2019, 02:00 AM
Bugman's Avatar
Re: Baro Sensor
Your 23.98 inHg is pretty close to being right on for 6000'
https://www.sablesys.com/support/tec...ltitude-table/
Bugman is offline
post #6 of 17 (permalink) Old 03-19-2019, 02:01 AM
Bugman's Avatar
Re: Baro Sensor
I doubt that the baro has anything to do with the map sensor, two independent sensors.
Bugman is offline
post #7 of 17 (permalink) Old 03-19-2019, 02:43 AM Thread Starter
Re: Baro Sensor
Ok, I didn't know if it relied on a baro reading to get a 'range' for the map sensor. I'm still learning how smart the computers in these things actually are.
I know pressure change has a noticable effect on a mechanical engine, but that's as far as my experience goes thus far.
So if the map code comes back any idea? I read a pile of other threads on the matter, but they seemed to have significant mpg loss and check engine lights.
post #8 of 17 (permalink) Old 03-19-2019, 03:06 AM
Bugman's Avatar
Re: Baro Sensor
If nothing else you could always just replace the map sensor.
Bugman is offline
post #9 of 17 (permalink) Old 03-19-2019, 03:53 AM Thread Starter
Re: Baro Sensor
Ok thanks. Not really excited about spending money on a maybe, so I'll see if it comes back first. And be sure to check codes again next time it drags a load. I also read about "over boost" codes, but couldn't discern if it could throw the p0236, or if was only the p0238.
That came to mind because it hadn't really been opened up until recently, not abused just worked a little harder than normal.
post #10 of 17 (permalink) Old 03-19-2019, 11:09 AM
Re: Baro Sensor
As I recall the MAP sensor will get “confused” if the MAP sees boost over 22psi and will show an out of range code. When this happens the PCM defaults to stored linear fuel tables (not dynamic, based on MAP, because it’s out of range). Now pending mods you have on your rig this may reduce HP/torque output. A work around is to install a boost fooler (regulator in MAP line) such that MAP never sees over 20 psi. Other option if running tunes is have programer to account for MAP overboost. Incidentally on the SD version of engine over boost results in a de-fueling which guys assume happens with the OBS, which my understanding is not the case.
If you feel a loss in power or noticeably more smoke, unhook the Wiring harness from MAP so PCM reverts to linear tables and if it drives more normal might be MAP sensor is booogered. If running tunes check with vendor to see if program files have accounted for above 22 psi boost.
Cheers,
j
Tan white tan 97 ECLB, D60 RSK SD springs front, airs bags rear, E4OD 4:10, intake, DP 4” exhaust
Red 97 F250 CC 3:55, D60 Air Locker front, 175/80s, T500, TW files, Tymar, SD I/C, 6.0 fan, E-air, E-Fuel, RSK, SD springs front/rear, 145 litre rear tank (now ZF-5
JCart is offline
Similar Threads
Map, baro pressure sensor madness! Juniorssrollin 6.0L Power Stroke Technical Info 15 03-20-2013 08:13 PM
baro pressure middlemanjw 1994-1997 Power Stroke Technical Info 1 09-11-2012 07:26 PM
Baro Sensor Sandia505 E-Series Power Stroke Vans 2 11-27-2009 06:06 AM
PCM BARO sensor? matthewd11 7.3L Power Stroke Technical Info 13 09-11-2009 05:51 PM
Map/Baro problem matthewd11 7.3L Power Stroke Technical Info 15 03-01-2008 04:59 AM
