Overdrive will not work! 97 F350 Auto 7.3 Diesel - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 1 (permalink) Old 03-18-2019, 06:25 PM Thread Starter
Hello,
I need some help here. I have a 1997 Ford F350 7.3 w/ Automatic transmission. My truck will not go into overdrive. The light on the shifter is stuck to off and is lit up.
I did replace the shifter and the button from OEM Ford parts and it did not work. I look at all the wiring and it all looks good. If I remove the button from the shifter and use a wire and jump the ground it will shift into overdrive. CRAZY!! You would think it would be the button but its not.
Any ideas here? Driving me CRAZY!!! Appreciate any help you can give.
firewalldown is offline
Similar Threads
Overdrive light off but still in overdrive honda313 7.3L Power Stroke Technical Info 3 08-19-2012 02:25 PM
97 2wd auto to 4x4 auto with 95 f350 parts ? Orangeracer 1994-1997 Power Stroke Technical Info 4 03-21-2012 05:56 AM
HELP!!!!!!!!!!!! Will my 97 auto pcm work in a 95 auto for testing purposes Sea97Stroker 1994-1997 Power Stroke Technical Info 5 10-29-2009 04:17 PM
overdrive doesn't work when cruise is on winkfab 1994-1997 Power Stroke Technical Info 0 05-26-2009 04:08 PM
overdrive dont work dieseltec192008 Transmission Related 1 03-05-2008 06:50 PM
