7.3L F250 Difficulty starting - PowerStrokeNation : Ford Powerstroke Diesel Forum
 3Likes
  • 1 Post By longjonsilver
  • 2 Post By Patrick Feeley
post #1 of 5 (permalink) Old 03-18-2019, 12:38 AM Thread Starter
All, my 1997 7.3L slowly became difficult to start. replaced glowplugs about 5yrs ago. very few miles since replaced. I noticed slot number 22 30A maxi fuse continues to blow after replacement. this controls the fuel line heater and glow plug controller. and power control system relay coil. any ideas what is going on, and how to test for culprit?
mark.huff is offline
post #2 of 5 (permalink) Old 03-18-2019, 12:55 AM
longjonsilver's Avatar
Re: 7.3L F250 Difficulty starting
Possibly a shorted fuel bowl heater , that will trip the fuse . Itís actually pretty common . Most guys simply unplug the bowl heat in the hopes of eliminating that blown fuse .
There is limited need for the fuel heater unless youíre in Canada or the northern Midwest I reckon .
Try unplugging it and see what happens .
JCart likes this.
longjonsilver is offline
post #3 of 5 (permalink) Old 03-19-2019, 12:27 AM
Patrick Feeley's Avatar
For checking the injector/glowplug wiring: From each valvecover gasket connection's outermost pins (2 per connector) to ground you should get 0.1 to 2 ohms (indicates good plug and wiring). From each valvecover gasket connection's center pin to each immediately adjacent pin, you should get around 3 ohms (indicates good injector solenoid and wiring). You should not get any continuity from any of the outer pins to the 3 inner pins (indicates no shorts between injector and glowplug wiring). You should also get 0 to 1 ohms from each of the external harness connectors outer pins back to the Glowplug Relay's large terminal on the GP side (indicates good wiring from external connections back to the relay).
To check the glowplug relay (GPR), measure the voltage drop across the GPR's large terminals. While the GPR is active (up to 1.5 to 2 minutes after the key is turned to Wait-to-Start) put your meter leads on the large terminals (one lead on one large terminal and the other lead on the other large terminal). The measures how much voltage is being "lost" across the relay. A reading of 0.3V or more indicates a bad relay. Also, check the relay’s control wires (smaller wires) disconnected from the relay for battery voltage at the Red/Light Green striped wire and ground at the Purple/Orange striped wire (check both when the key is turned to Wait-to-Start).
Cheers!
JCart and Lt.Dan like this.
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3Ē DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
post #4 of 5 (permalink) Old 03-22-2019, 04:24 AM
Project Shamu
Lt.Dan's Avatar
To check the glowplug relay (GPR), measure the voltage drop across the GPR's large terminals. While the GPR is active (up to 1.5 to 2 minutes after the key is turned to Wait-to-Start) put your meter leads on the large terminals (one lead on one large terminal and the other lead on the other large terminal). The measures how much voltage is being "lost" across the relay. A reading of 0.3V or more indicates a bad relay. Also, check the relayís control wires (smaller wires) disconnected from the relay for battery voltage at the Red/Light Green striped wire and ground at the Purple/Orange striped wire (check both when the key is turned to Wait-to-Start).
Cheers!
Lots of good info there, saved.
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 378,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
1983 F150 SCSB Flareside, 302 w/ AOD Trans
2002 F450 SCFB, 7.3 PSD 2wd w/ 144,000 miles
SOLD
Lt.Dan is offline
post #5 of 5 (permalink) Old 03-23-2019, 10:03 AM
If you need to replace glow plugs use only Ford stock ones, other brands can be problematic as the ends can swell break or burn off. If glow plug relay needs replacing the White Rogers (Stancor) Relay PN 586-902 are much more robust then stock. I’ve not replaced one, once installed on our trucks and the stock ones typically I’d get 1.5 year out of them.
If you look in bottom of fuel filter canister, once filter and fuel is drained there should be a flat plate with a metal wire running around the plate (fuel heater). Typically the wire become loose off the plate and shorts the fuse. Lots of guys just unplug the harness on the outside and tape up the end to prevent shorting on the wire end of harness. If you remove heater plate remember the stand pipe inside filter housing is reverse thread. From what you’ve explained I’d say three things as noted above, shorted fuel heater, GP Relay and/or glow plugs.
Typically where I reside in Western Canada winter can be cold at times, I usually unplug and/or remove as preventative maintanence, the fuel heaters are a poor design. With winter fuel diesel I’ve never had a gel problem since 1990, check with your fuel supplier in your jurisdiction as winter fuel additives may be different.
Cheers,
j
Tan white tan 97 ECLB, D60 RSK SD springs front, airs bags rear, E4OD 4:10, intake, DP 4Ē exhaust
Red 97 F250 CC 3:55, D60 Air Locker front, 175/80s, T500, TW files, Tymar, SD I/C, 6.0 fan, E-air, E-Fuel, RSK, SD springs front/rear, 145 litre rear tank (now ZF-5
JCart is offline
Similar Threads
Difficulty of 6.0 needed upgrades to 03 Excursion Awhole New To The Nation 7 02-22-2018 01:28 PM
trans go tugger difficulty instaull Orangeracer 1994-1997 Power Stroke Technical Info 9 12-19-2011 03:10 AM
Difficulty Starting north2south006 6.0L Power Stroke Technical Info 7 12-16-2011 03:52 AM
Difficulty of Installing some Factroy Options... Lifted94XLT 1999-2010 Super Duty General Aftermarket 0 08-30-2011 01:42 AM
Modification Difficulty Chart PowerHungry 7.3L Power Stroke - Aftermarket & Performance 50 11-06-2009 03:46 AM
