1996 f350 powerstroke cclb no start - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 03-13-2019, 03:29 AM Thread Starter
So i was driving my truck and all of a sudden it died as if it someone just shut the key off and so i checked all the fuses they were good. Changed out the cps i had an extra in the glove box still nothing the wts light doesnt come on and the check engine light stays on i have tried hooking a cheaper obd2 reader to it but it doesnt come up with anything and my cts edge doesnt wont work so i csnt pull up codes on that cause it says it cant connect to truck im lost please help anyone!!??
Derrick Diffy Hobson is offline
post #2 of 5 (permalink) Old 03-14-2019, 01:03 AM
Patrick Feeley's Avatar
Re: 1996 f350 powerstroke cclb no start
If you haven't already check the underhood fuses with a meter (not just visually). Is there power at underhood fuses #9 and #22? If the PCM is getting power, you might need to check and see if maybe one of the sensors that uses the 5V reference voltage might have shorted. They would be the Injection Control Pressure (ICP), CPS, Throttle Position Sensor (TPS), Barometric (BARO), Exhaust Back Pressure (EBP), and Manifold Absolute Pressure (MAP). You can try disconnecting each one, one at a time to see if the WTS comes on when the key is on. If not, plug it back in and move to the next one. I would try ICP and EBP as the first ones. At any rate, you should get 5V on the Brown/White stripe wire on each of those sensors (unless there is a short in the circuit or no power to PCM). Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3” DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
post #3 of 5 (permalink) Old 03-14-2019, 02:12 AM
That happened to me years back. The fuel heater, at the bottom of the fuel bowl had broken and shorted out. I can't remember the fuse number but shut down the truck. Good luck!
NM Oil Burner is offline
post #4 of 5 (permalink) Old 03-14-2019, 02:40 AM
In addition to what NM... said above, pull out your fuel filter and look to bottom of bowl you should see a thin sold wire running around the bowl and it should not be hanging or broken. As I recall it shares same circuit as the PCM, so it can intermittently short and also fully short and cause shut down, no start condition. Fuse is outside (I think) underhood in fuse box.
j
Tan white tan 97 ECLB, D60 RSK SD springs front, airs bags rear, E4OD 4:10, intake, DP 4” exhaust
Red 97 F250 CC 3:55, D60 Air Locker front, 175/80s, T500, TW files, Tymar, SD I/C, 6.0 fan, E-air, E-Fuel, RSK, SD springs front/rear, 145 litre rear tank (now ZF-5
JCart is offline
post #5 of 5 (permalink) Old 03-14-2019, 10:48 PM
Fuel Heater is #22 in underhood box. Cheers!
Similar Threads
1996 f350 no wts, no start jkeller831 1994-1997 Power Stroke Technical Info 3 02-09-2014 07:20 PM
