A/C has no power. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 03-11-2019, 11:52 PM Thread Starter
A/C has no power.
Hello! Im new on the here though i have come to this site before for help. I couldn't find a thread with the answers im looking for. So im sorry if this has been covered before.
My A/C clutch has no power. Fuse is good. I tried to jump the connector out to trick it to come on and, nothing. I followed the wiring harness down stream to the next connector to see if it was damaged or burnt up, it looks to be in good condition. Im not sure where to go from there. If anyone could help I'd greatly appreciate it!
Nick_98_97-7.3L is offline
post #2 of 7 (permalink) Old 03-12-2019, 12:30 AM
alleged moderator
tjctransport's Avatar
Re: A/C has no power.
ac clutch gets it power from the low pressure switch. if refrigerant is low, the switch will open and no power will be sent to the clutch
tom
tjctransport is offline
post #3 of 7 (permalink) Old 03-12-2019, 12:47 AM Thread Starter
The low pressure switch is what i jumped out. It will come on with that thinking the pressure is correct right? Thats what has worked for me in the past.
post #4 of 7 (permalink) Old 03-12-2019, 01:12 PM
alleged moderator
it should. are you getting power into the low side switch?
there is also a high pressure switch that will open cutting power to the clutch if something in the system plugs up and head pressure rises over around 400 PSI
tom
post #5 of 7 (permalink) Old 03-12-2019, 10:04 PM
don't play well w others
Dustybumpers's Avatar
Low pressure switch is by the dryer
high pressure switch is by the compressor
Charlie
"A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool."
Dustybumpers is offline
post #6 of 7 (permalink) Old 03-16-2019, 01:37 PM
longjonsilver's Avatar
I have had several trucks that the pressure switch connector pigtail on the compressor have had bad connections and caused the compressor to be inoperable. Try wiggling that connection or gently crimping the connectors to get a better connection .
longjonsilver is offline
post #7 of 7 (permalink) Old 03-16-2019, 02:28 PM
Patrick Feeley's Avatar
Yup! Same with mine. Cheers!
Patrick Feeley is offline
Similar Threads
7.3L Has no power 69Porterj New To The Nation 5 04-05-2012 11:39 PM
02 f-250 7.3 no gauges no power windows no power locks no radio???? RMutz27 7.3L Power Stroke Technical Info 2 12-24-2011 04:39 AM
Spartan Stock NR - has no power drservo 6.4L Power Stroke - Aftermarket & Performance 8 08-25-2010 05:42 PM
truck has no power regcab 6.0L Power Stroke Technical Info 0 04-03-2009 10:05 PM
95 has no power [email protected] 1994-1997 Power Stroke Technical Info 8 09-06-2008 02:20 AM
