F350 Front Spring Options - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 02-28-2019, 02:07 PM Thread Starter
Diabolic1's Avatar
Are there different obs spring rates like the SD trucks have? Lifted, stock height, aftermarket???
I also have a question about the rear spring block. If I wanted a 5” block to replace a stock F350 block, do I need one that is flat or one with an angle?
1997 CCSB, 7.3/E4OD
KC TP38R, CNC Fab Bellowed Up-Pipes, Full Force Stg 1 injectors, 3" DP, 4" exhaust, CNC Fab HPOP, Mark F E-Fuel, 7.3 Intercooler, 1.0 Exhaust Housing, TS Chip, remote coolant filter, and VB.
Diabolic1 is offline
post #2 of 3 (permalink) Old 03-01-2019, 11:54 PM Thread Starter
Diabolic1's Avatar
Re: F350 Front Spring Options
Nobody huh?
1997 CCSB, 7.3/E4OD
post #3 of 3 (permalink) Old 03-02-2019, 02:51 AM
I believe the F350s may have had a special order for stiffer springs for a plough package from the factory although I don’t recall spring codes. There was also F450 4x2 springs that had big arc to them. Thinking there are aftermarket F350 lift springs for sure, like Deaver springs. Other alternative is Shackle Reversal Kit with SD springs front and rear. Or 05 and newer coil over front and with SD rear end to maintain wheel stud dimensions.
Precision Metal Fabrications, makes a true bolt on RSK and it comes in different lift heights.
Rear blocks, with 5” lift you might wanna shim the rear end along with dropping the driveshaft at the pillow block.
j
Tan white tan 97 ECLB, D60 RSK SD springs front, airs bags rear, E4OD 4:10, intake, DP 4” exhaust
Red 97 F250 CC 3:55, D60 Air Locker front, 175/80s, T500, TW files, Tymar, SD I/C, 6.0 fan, E-air, E-Fuel, RSK, SD springs front/rear, 145 litre rear tank (now ZF-5
JCart is offline
Similar Threads
Stock-height spring options? CtG Power Stroke Excursions 5 08-10-2015 07:26 PM
Options to Options 70jeeper 11-16 6.7L Power Stroke Technical Info 7 10-19-2013 07:03 PM
F250 4x4 Spring Replacement Options. Sea97Stroker 1994-1997 OBS Power Stroke - Aftermarket & Performance 6 10-21-2010 02:52 AM
Broken rear spring, need advice on options NH OIL BURNER 7.3L Power Stroke Technical Info 9 06-07-2010 06:45 AM
