97 ps 198k - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 02-28-2019, 02:43 AM Thread Starter
Riddle's Avatar
97 ps 198k
Gutless. Truck starts trembling even on a small grade and down shifts. Fresh filters/service. Noticed today while in park, hold throttle down at any rpm within a few seconds without moving my foot at all the rpms drop drastically. Almost like putting a load against the motor. Thoughts?
Riddle is offline
post #2 of 4 (permalink) Old 02-28-2019, 06:52 AM
Diabolic1's Avatar
Re: 97 ps 198k
Fuel supply issue. Filter or regulator screen clogged? Put a test gauge on it or it’s all just guessing.
1997 CCSB, 7.3/E4OD
KC TP38R, CNC Fab Bellowed Up-Pipes, Full Force Stg 1 injectors, 3" DP, 4" exhaust, CNC Fab HPOP, Mark F E-Fuel, 7.3 Intercooler, 1.0 Exhaust Housing, TS Chip, remote coolant filter, and VB.
Diabolic1 is offline
post #3 of 4 (permalink) Old 02-28-2019, 01:02 PM
Bugman's Avatar
Re: 97 ps 198k
You really need to get a reader that can see Fords live data while the truck is running.
Your problem can be any number of things starting with the fuel or all the way to the oil that you are using.
Bugman is offline
post #4 of 4 (permalink) Old 02-28-2019, 02:42 PM Thread Starter
Riddle's Avatar
Thanks for the feedback. For what it’s worth I took the tps off the pedal assembly sprayed it with wd-40 and the only noticeable change was now you can hold the rpm’s wherever you wish (in park) and it holds there. It no longer backs off on its own. But didn’t change the way it runs under power
Riddle is offline
Similar Threads
Fair asking price for bone stock 08 6.4L with 198k miles? jncasey 6.4L Power Stroke - Technical Info 3 12-06-2017 08:52 PM
97 F250 PS Shifts Hard rainmaker Transmission Related 1 08-29-2010 06:29 PM
new to PS nation but not new to PS pistol60 New To The Nation 2 05-15-2010 04:02 AM
97 ps wont start help fordracing 1994-1997 Power Stroke Technical Info 6 01-30-2010 05:17 AM
97 PS key on no power won't start ... ready to pull my hair out !!! netpro 1994-1997 Power Stroke Technical Info 4 06-29-2009 03:33 AM
