Real world towing? - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By Diabolic1
  • 1 Post By trblemknredneck2
post #1 of 9 (permalink) Old 02-25-2019, 08:05 PM Thread Starter
Lmm2013's Avatar
Real world towing?
I have a 1996 F350 7.3L DRW with 4.10 rear end. I am new to the Diesel world and I have been towing an enclosed car trailer loaded that's around 7000# and the truck seems to struggle to pass 65mph or hold it on hills. I know the 7.3 isn't the most burly thing in the world but can this be right. Just wondering if I have an issue truck runs great otherwise, thanks all for the help!
Lmm2013 is offline
post #2 of 9 (permalink) Old 02-25-2019, 08:25 PM
alleged moderator
tjctransport's Avatar
Re: Real world towing?
that sounds about rite. and with 7,000 in the trailer, you are running down the road around 14-15 k lbs.
no way i would be going that fast with that load.
tom
tjctransport is offline
post #3 of 9 (permalink) Old 02-26-2019, 12:38 AM Thread Starter
Lmm2013's Avatar
Thanks bud, you have a good point. I appreciate it.
Lmm2013 is offline
post #4 of 9 (permalink) Old 02-27-2019, 12:28 PM
Copperhead's Avatar
With my 96 F-250,...and 4:10 rear gears,.. I tow 7000lbs quite often,...so I can attest to what you're saying.
The main problem is,...the small Injectors in these trucks. Upgrade those,....get you a chip, some gauges, new Down-Pipe (or complete exhaust), better air intake and it'll be a completely different truck.
The downfall to this,......be prepared to spend on average of about 2000 bucks to do these mods.
Copperhead is offline
post #5 of 9 (permalink) Old 02-27-2019, 02:03 PM
Project Shamu
Lt.Dan's Avatar
Yup, sounds about right, I use to do the same thing with the exact same setup. But now with some mods, I'm towing 13,000lbs at 65mph and 55mph up most hills.
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 378,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
1983 F150 SCSB Flareside, 302 w/ AOD Trans
2002 F450 SCFB, 7.3 PSD 2wd w/ 144,000 miles
SOLD
Lt.Dan is offline
post #6 of 9 (permalink) Old 02-27-2019, 04:10 PM
College Student
Down #### to third if you have a 4EOD and keep it around 2,500-2,700 rpm. With only 7K it will be more than fine.
I put baby swamp injectors and a KCTP38R turbo and still struggled to pull hills at speed due to EGT's getting too hot.
Injectors, tune, exhaust, intake, and a intercooler will solve your problems and make it nice to tow with. At the end of the day though, it's still not a race car.
95 Auto. 4.10 gears. SCLB. Stock besides Baby Swamps Injectors and TS-6 chip with swamps tunes. AFE MaxFlow. Glowshift trans, pyro, and boost. 6.0 IC KC TP38R. Converted EBPV to exhaust brake.
Cumminsdurastroke is offline
post #7 of 9 (permalink) Old 02-27-2019, 05:22 PM
Depending on your location, weather, elevation the above mods along with intercooler might still be too hot, then you could look at water injection to control EGTs. It on my list of to does, just down a ways....
j
Tan white tan 97 ECLB, D60 RSK SD springs front, airs bags rear, E4OD 4:10, intake, DP 4” exhaust
Red 97 F250 CC 3:55, D60 Air Locker front, 175/80s, T500, TW files, Tymar, SD I/C, 6.0 fan, E-air, E-Fuel, RSK, SD springs front/rear, 145 litre rear tank (now ZF-5
JCart is offline
post #8 of 9 (permalink) Old 02-27-2019, 06:53 PM
Diabolic1's Avatar
I too have the KCTP38R, Full Force Injectors, 4.10 gear and bellowed up pipes. I pull a 9000# trailer 70mph with zero issues at all. No real egt issues on heavy tow tune.
JCart likes this.
1997 CCSB, 7.3/E4OD
KC TP38R, CNC Fab Bellowed Up-Pipes, Full Force Stg 1 injectors, 3" DP, 4" exhaust, CNC Fab HPOP, Mark F E-Fuel, 7.3 Intercooler, 1.0 Exhaust Housing, TS Chip, remote coolant filter, and VB.
Diabolic1 is offline
post #9 of 9 (permalink) Old 02-27-2019, 08:50 PM
this is the exact reason I've done my upgrades, pulling my empty 34 ft 5th wheel at 9k if there was any kind of head wind I couldnt make it over 50mph in my 95 f350 drw with 4.10 gears. truck now has 180/80 rosewood injectors with dieselsite ball bearing wicked turbo kit 66/94 option, bellowed up pipes, 3 inch downpipe to 4 inch straight exhaust, adrenalin hpop, banks intercooler, s&B intake, hydra chip with gearhead tunes and a BTS E40D in it. I haven't pulled the 5th wheel yet but the car trailer loaded at 7k behind it I have no problem passing anyone and running 75 down the highway with it. My EGT can get a little warm but it seems to be more if your lugging it down around 1800 rpm or less or if your foots in it hard
JCart likes this.
trblemknredneck2 is offline
Similar Threads
Real People, Real God Powerstroke Racer Politics and Religion 0 01-20-2016 02:17 PM
I need real world grille pictures Santa Gertrudis 6.4L Power Stroke - Aftermarket & Performance 34 11-24-2010 01:07 AM
REAL world SCT review with NO BS mileage numbers!!! bubbamcnasty 6.4L Power Stroke - Aftermarket & Performance 19 10-18-2010 03:58 PM
Real World Fuel Mileage 7.3 Mtack Power Stroke Excursions 12 07-23-2010 12:29 PM
Need Help Real Bad, Real Fast ZCMiller 1994-1997 Power Stroke Technical Info 21 04-02-2010 03:56 PM
