97 not cranking! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 02-25-2019, 12:37 PM Thread Starter
Tmcpherson's Avatar
97 not cranking!
Yesterday I was using if all day, no issues. Stopped at a few places and the truck started as usual. In the night I again went to start it. But it don’t turn over. I hear the starter solenoid click and I hear the starter click but it doesn’t turn over. Batteries are at 12.3v and the terminals are tight.
What does this sound like to you? Bad starter or solenoid? Any other thoughts?
Thanks for any help
That OBS Life
Tmcpherson is offline
post #2 of 2 (permalink) Old 02-25-2019, 04:42 PM
Native Texan
masakimm's Avatar
Garage
Re: 97 not cranking!
Could be bad starter could be bad solenoid could be bad or loose cable. just have to test start at solenoid make sure u have voltage going in and coming out of solenoid when cranking if not then start there if it does go to the starter does it have voltage while cranking if not find out why if it does probably a starter. with out testing u can throw parts at it all day long and may or may not fix it. Now i am guessing the wire that triggers the solenoid is working since u say it is clicking make sure it is what is clicking.
Give it to Mikey. He won't eat it he hates everything. Hey Mikey!! He Likes It.
Upgrades:
masakimm is offline
Similar Threads
Truck fires while cranking and stop when not cranking Welder08 6.0L Power Stroke Technical Info 5 04-17-2018 01:10 PM
7.3 not cranking 7.3maniac 7.3L Power Stroke Technical Info 2 02-19-2013 04:53 PM
95 F-Superduty , will not stop cranking after Engine swap 97XLT7.3 1994-1997 Power Stroke Technical Info 8 04-15-2011 02:52 PM
not cranking...??? tturbonegro 7.3L Power Stroke Technical Info 12 02-06-2009 12:42 AM
cranking and cold cranking amps for 7.3 hazardiz 7.3L Power Stroke Technical Info 12 01-12-2009 05:06 PM
