Headlight issues - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 02-24-2019, 03:41 AM Thread Starter
Headlight issues
Hey guys. I just had to replace my batteries and now I have no headlights. I had no headlight issues prior to the batteries dying. There is power at the fuses but not at the light sockets. The switch gets hot and it is clicking. When it clicks the red wire with a yellow stripe gets power, but only with the click. I'm assuming the switch is bad but thought I would see if anyone had any input. Thanks in advance.
brestored is offline
post #2 of 2 (permalink) Old 02-24-2019, 02:20 PM
Patrick Feeley's Avatar
Re: Headlight issues
I've attached a gif of the headlamp wiring diagram and the main light switch tests. It's probably the main switch, but you can't rule out the multifunction switch either. Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3” DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
Similar Threads
OBS headlight issues! (blinker) Tmcpherson 1994-1997 Power Stroke Technical Info 20 02-13-2017 10:06 PM
OBS headlight issues! (blinker) Tmcpherson Aftermarket Electronics and Lighting 2 02-09-2017 07:13 PM
Issues issues issues ICP? justaguywithatruck 6.0L Power Stroke Technical Info 6 11-10-2016 11:50 AM
Installed the headlight harness,new headlight lenses and light bulbs today bignastyGS 1994-1997 OBS Power Stroke - Aftermarket & Performance 3 02-17-2013 03:06 PM
Headlight Issues BigSal 6.0L Power Stroke Technical Info 10 12-18-2012 12:44 PM
