OBS ZF5 weird vibration issue - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
post #1 of 13 (permalink) Old 02-22-2019, 04:05 AM Thread Starter
Tristanmoore001's Avatar
So my truck was driving smooth up until a couple days ago and I haven't been able to find any write ups that had similar issues as me. First off my truck leaks transmission fluid, but it has been leaking since the day after i got it rebuilt so I don't think that's what is causing the issue. Anyways, my symptoms are hard vibration felt in the stick as soon as i hit 50 mph and above, but only feel the whole truck vibrating hard when in neutral going 50 mph and above. If i'm going under 50, there is no vibration felt in the truck or stick at all. If the truck is in gear going over 50 the vibration ranges from very light to non existent besides the stick itself vibrating, but again very hard vibration if in neutral going over 50. Has anyone had similar problems, and what did they do to fix it?
97 4x4 F350 XLT OBS Powerstroke CCSB- ZF-5 manual trans, 6637 cold air intake, TS6 chip, straight piped 4 inch turboback pretire side exit, 4 pillar gauge w/ diff temp, EGT, boost, and HPOP pressure, ATS diff cover, dual alpine 10'' subs w/ alpine component speakers, B code rear springs
Tristanmoore001 is offline
post #2 of 13 (permalink) Old 02-22-2019, 09:13 AM
PSN intsigator
heavydoc's Avatar
Re: OBS ZF5 weird vibration issue
So many possibilities, if you fell no vibration in the seat I would rule out driveline and rearend. I would prolly start with checking the trans oil for metal, maybe a bearing or synchro. Or throughout bearing, pilot bearing
Sent from my super awesome outdated Samsung phone while waiting for masakimms# 500mA overdraw draw to catch fire which turd will be blamed for and we will be sitting on dustybumpers tailgate watching the fire and plotting against yommy.
96 F350 rclb drw 2wd psd (built not bought)
01 Excursion Limited 4wd psd (the wifes ride)
02 F350 cclb drw 4wd psd (the land yacht)
heavydoc is online now
post #3 of 13 (permalink) Old 02-22-2019, 03:48 PM
longjonsilver's Avatar
I had a similar vibration and found that nut on the output yoke had fallen off and the universal joint kept it from being pitched away .
longjonsilver is offline
post #4 of 13 (permalink) Old 02-23-2019, 12:42 AM
Patrick Feeley's Avatar
I had the same thing happen on my 94's 2wd ZF5-42. Just for information the output shaft yoke nut is a one-time only use nut (if you take it off you have to replace it). With the nut falling off, there was also a nice leak at the output shaft seal. The part I got was Ford part F81Z-7045-CA (about $5.83 online, list is $8.83) if anyone needs it. Cheers!
Patrick Feeley is offline
post #5 of 13 (permalink) Old 02-23-2019, 02:02 AM
Yeah I ended up cleaning the nut and threads real well applied blue loctite and slapped it back on there .
Anyway its worth looking at for sure
post #6 of 13 (permalink) Old 02-23-2019, 07:01 AM Thread Starter
I'll make sure to do that. I just bought fast coolers manual transmission cooler kit so I'll look at the old fluid when I install those.
post #7 of 13 (permalink) Old 02-23-2019, 07:04 AM Thread Starter
Where should I be looking for that nut? Is it where the rear driveshaft connects to the transfer case?
post #8 of 13 (permalink) Old 02-23-2019, 09:17 AM
PSN intsigator
heavydoc's Avatar
If it's 2wd it should just be on the differential side of the drive line, the transmission side will slip in and out. Speaking of that I've seen a few slip yolks (transmission side) get sloppy and cause a vibration.
post #9 of 13 (permalink) Old 02-24-2019, 06:15 PM Thread Starter
Well I've noticed another weird driving characteristic. When I'm going 50+ and let off the accelerator, all vibration stops including the vibration felt in the stick, which I normally feel going 50+. Any thoughts?
post #10 of 13 (permalink) Old 02-24-2019, 06:39 PM
Check rear pinion nut on driveline.
Tan white tan 97 ECLB, D60 RSK SD springs front, airs bags rear, E4OD 4:10, intake, DP 4 exhaust
Red 97 F250 CC 3:55, D60 Air Locker front, 175/80s, T500, TW files, Tymar, SD I/C, 6.0 fan, E-air, E-Fuel, RSK, SD springs front/rear, 145 litre rear tank (now ZF-5
JCart is offline
Similar Threads
weird idle vibration travis182008 7.3L Power Stroke Technical Info 16 01-04-2013 01:40 AM
Weird hum, vibration SdPj 7.3L Power Stroke Technical Info 5 05-06-2012 10:04 PM
Weird Motor Vibration brfootball45 1994-1997 Power Stroke Technical Info 6 12-08-2011 01:43 AM
weird vibration maddzack 6.0L Power Stroke Technical Info 5 05-26-2009 12:30 AM
Weird vibration or hopping?? powerstroke1979 7.3L Power Stroke Technical Info 24 04-17-2008 07:03 PM
