pitman arm/steering box - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 02-18-2019, 01:43 PM Thread Starter
Exclamation pitman arm/steering box
Hi guys Im buying my first powerstroke in a couple days. 96 4x4 5 speed 7.3. All it needs is the three steering box bolts, pitman arm nut, and starter. My question is now, how do i get it on the trailer? will i be able to push/winch it on and kick the tires as i go to keep it strait?
Seventree69 is offline
post #2 of 6 (permalink) Old 02-19-2019, 03:46 AM
Re: pitman arm/steering box
Welcome,
Why not buy parts and install prior to trailering? If tie rod is on you could ratchet strap it off the axle from each end to keep wheels straight Iím thinking.
For a starter buy the SD 7.3 one for a 2000-2003 as itís a gear reduction, spins way faster and bolts right up, in fact only need two bolts (compared to stock 3). You might have to enlarge one ring connector on stock wiring harness. And the SD starter is less expensive too.
Cheers,
j
Tan white tan 97 ECLB, D60 RSK SD springs front, airs bags rear, E4OD 4:10, intake, DP 4Ē exhaust
Red 97 F250 CC 3:55, D60 Air Locker front, 175/80s, T500, TW files, Tymar, SD I/C, 6.0 fan, E-air, E-Fuel, RSK, SD springs front/rear, 145 litre rear tank (now ZF-5
JCart is offline
post #3 of 6 (permalink) Old 02-19-2019, 04:21 AM
Project Shamu
Lt.Dan's Avatar
Originally Posted by JCart View Post
Welcome,
Cheers,
j
Actually you want the 2003 model, the 99-2002 models are not gear reduction.
I had the auto zone guy pull a starter for every year truck. Only the 2003 models are gear reduction.
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 378,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
1983 F150 SCSB Flareside, 302 w/ AOD Trans
2002 F450 SCFB, 7.3 PSD 2wd w/ 144,000 miles
SOLD
Lt.Dan is offline
post #4 of 6 (permalink) Old 02-19-2019, 04:36 AM
Thanks for the clarification LT.Dan, guess the guys at my store have always provided the G reduction one for me and I have always thought the former where as well.
Thanks again,
j
JCart is offline
post #5 of 6 (permalink) Old 02-19-2019, 04:42 AM
Project Shamu
Lt.Dan's Avatar
Thanks again,
j
No worries, I was doing research for a better starter at the time, and I had him pull ever year from 97 up to 2012, looking at 6.0, 6.4 and 6.7 starters to see if they were worth trying to modify the nose cone, etc, to fit my 7.3.
The only one worth it was the 2003 model. No modifications and better than the 96 starter.
SOLD
Lt.Dan is offline
post #6 of 6 (permalink) Old 02-19-2019, 04:43 AM
Project Shamu
Lt.Dan's Avatar
To answer your question, yes, you can just kick the tires to get it up on a trailer, just be careful!
SOLD
Lt.Dan is offline
Similar Threads
Steering box/ Pitman Arm question mrvmax 1994-1997 Power Stroke Technical Info 9 09-18-2016 05:08 PM
steering connection loose on pitman arm 1995_F250_P/S 1994-1997 Power Stroke Technical Info 4 10-11-2014 08:15 PM
08 f350 pitman arm fit 02 steering box? John Martens Suspension and Drivetrain 1 11-02-2013 01:16 PM
