Decreased power - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 02-02-2019, 06:51 PM Thread Starter
Decreased power
My 97 350 7.3 has, when cold, intermittent reduced power and an loud air vacumn type sound from exhaust. Step on gas it goes away immediately. Is the turbo going? Any ideas? Thanks
mak270 is offline
post #2 of 4 (permalink) Old 02-02-2019, 07:21 PM
College Student
Re: Decreased power
Exhaust Back Pressure Valve is closing. You can delete it with a new turbo pedestal or unplug it. Plug is underneath the compressor housing. If you unplug it, make sure the valve is open.
95 Auto. 4.10 gears. SCLB. Stock besides Baby Swamps Injectors and TS-6 chip with swamps tunes. AFE MaxFlow. Glowshift trans, pyro, and boost. 6.0 IC KC TP38R. Converted EBPV to exhaust brake.
Cumminsdurastroke is offline
post #3 of 4 (permalink) Old 02-02-2019, 07:30 PM
Bugman's Avatar
Re: Decreased power
You can also wire it open when you unplug it if you have any worries about it closing.
Bugman is offline
post #4 of 4 (permalink) Old 02-03-2019, 12:07 AM
Re: Decreased power
Mak270, welcome to PSN. To follow up on the above comments. No your turbo is not going out. Your 7.3 has what is called and exhaust back pressure valve on it (EBPV) from the factory it is located just after the exhaust side on the turbo and before the exhaust down pipe, passenger side rear of block. The power control module, monitors oil and antifreeze temps and when cold activates the EBPV, which is a butterfly valve in the exhaust flow. When it comes on that’s the sound you hear. The notion is that it will heat up the engine faster than without one. Many guys unplug them and or gutt the EBPV right out. This valve is activated with engine oil pressure and over time, leaks will usually start to happen in a couple of areas. To learn more do a search on gutting the EBPV.
cheers,
j
Tan white tan 97 ECLB, D60 RSK SD springs front, airs bags rear, E4OD 4:10, intake, DP 4” exhaust
Red 97 F250 CC 3:55, D60 Air Locker front, 175/80s, T500, TW files, Tymar, SD I/C, 6.0 fan, E-air, E-Fuel, RSK, SD springs front/rear, 145 litre rear tank (now ZF-5
JCart is offline
Similar Threads
Fast Climbing EGT's/Decreased Top-End Performance 02f350cp 7.3L Power Stroke Technical Info 1 06-29-2016 01:04 PM
Installing power tow mirrors on my non power mirror door jhyder408 7.3L Power Stroke Technical Info 6 10-02-2010 04:19 AM
94.5 7.3 power stroke no power when warm sixpackca 7.3L Power Stroke Technical Info 5 11-10-2009 02:54 PM
Power Steering Vs. Power Braking theSLEEPER 7.3L Power Stroke Technical Info 12 05-01-2009 02:31 PM
97 power stroke barely starts runs rough no power htcafe 1994-1997 Power Stroke Technical Info 9 06-07-2008 08:21 AM
