Truck shaking badly - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 02-02-2019, 04:07 PM Thread Starter
Truck shaking badly
Hello, i have a 97 cclb 4x4 auto
The other day i got off the highway and my truck was shifting hard and the speedometer was going whack. I did some research and some have had luck curing it with a new speed sensor. I tried this and it seemes to be back to normal. Just running some errands today and while driving, hit a small bump and truck started shaking crazy, coffee went flying, i thought maybe something straight up broke. My speedometer and odometer both went dead temporarily, seems like a loose connection, because i Marty McFly'd it and it came back. My truck also has a 6 inch lift and not the best tires. It had been driving fine for a while. Can that shaking be related to the PSOM?
This truck is kicking my ass and i just need to get by a little longer untill i can get something else.
I am no mechanic and my experience is limited. Any advice on where to start and check? It wasnt shaking the whole time, and it seemed to occur after hitting small bumps. Pulling over and start driving again it seemed fine... until the. Ext bump
Milkstake is offline
post #2 of 4 (permalink) Old 02-03-2019, 06:56 PM
Diabolic1's Avatar
Re: Truck shaking badly
Shaking as in the tires are shaking or as in the engine is missing?
1997 CCSB, 7.3/E4OD
KC TP38R, CNC Fab Bellowed Up-Pipes, Full Force Stg 1 injectors, 3" DP, 4" exhaust, CNC Fab HPOP, Mark F E-Fuel, 7.3 Intercooler, 1.0 Exhaust Housing, TS Chip, remote coolant filter, and VB.
Diabolic1 is offline
post #3 of 4 (permalink) Old 02-03-2019, 07:48 PM Thread Starter
I had death wobble. But it is now fixed. I had a bad driver tire that caused my passenger wheel assembly to come loose and shock absorber bushing was shot. I rotated tires, tightened up wheel hub and replaced shock bushing and now i think its good. That death wobble is some scary crap.
post #4 of 4 (permalink) Old 02-03-2019, 07:53 PM
Bugman's Avatar
There are a hundred different things that can cause that death wobble.
I have had it on a few company trucks but never on my PS, thank god.
It makes for a scary few moments until you either get slowed down or it stops.
Bugman is offline
Similar Threads
engine smoking badly and a few dtc's jrfonte 6.0L Power Stroke Technical Info 30 12-01-2009 11:02 PM
We need this, badly. Big Bore 7.3L Power Stroke - Aftermarket & Performance 18 09-09-2009 05:38 PM
CD Player Skipping badly!!! Natch02 Car & Truck Audio 8 12-02-2008 12:34 AM
finally got truck to run smoking badly linkbelt 7.3L Power Stroke Technical Info 3 11-14-2008 04:36 PM
