hard acceleration/ power issues - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 01-31-2019, 11:38 AM Thread Starter
joserollin's Avatar
Hello everyone I'm new to this forum and also a recent owner of a 97 f250 crew cab 4x4 the truck was in rough conditions when I purchased it and have replaced a lot of sensors and parts, but the issue I'm having is say I'm at a red light and accelerate hard the truck hesitates and then slowly powers up as the RPMS slowly get up this issue I have had since I bought the truck even does it if im on the freeway and I want to pass someone up. I have the Torque pro app all numbers look good expect the hp number shows I max out at 120HP at WOT.
This is the list of parts I have replaced since I owned the truck and all the things I have checked to figure out my issue.
fuel pump 7 months ago
fuel pressure shim 7 months ago
IPR last week
ICP/ pigtail 3 months ago
6637 air filter
3 inch diamond downpipe last week
HPOP shows 2400, 2500 at WOT idles around 580
IPR 11/12% at idle and 35% WOT
the MAP shows slow increase till about 8.0 then shoots up to 14,15 WOT
fuel pressure is at 50,65 at idle
on the car gauge app I ran
ran buzz test passed
passed contribution test
no check engine light or codes
EBPV is disconnected and when I did the downpipe I made sure the flap is wide open
I do have a leaks on both Manifolds
at this point I don't know what else to do or check I don't have a programmer and the truck idles smooth HELP!
joserollin is offline
post #2 of 12 (permalink) Old 01-31-2019, 01:37 PM
longjonsilver's Avatar
Re: hard acceleration/ power issues
As far as manifold leaks go are they cylinder head to manifold leaks ? Are there any up pipe to turbo leaks ? How bad are the leaks ? Can you actually hear it ticking ?
longjonsilver is offline
post #3 of 12 (permalink) Old 01-31-2019, 03:29 PM Thread Starter
joserollin's Avatar
sorry but yes I got the dreaded ticking noise at the exhaust manifold gaskets by cylinder 7,8 so I got a leak on both sides on 1 cylinder each.
post #4 of 12 (permalink) Old 01-31-2019, 03:30 PM Thread Starter
joserollin's Avatar
the Up pipes are in good shape though no leaks there
post #5 of 12 (permalink) Old 01-31-2019, 10:47 PM
How many miles on it ?
post #6 of 12 (permalink) Old 02-01-2019, 04:11 AM Thread Starter
joserollin's Avatar
It has 351,000
post #7 of 12 (permalink) Old 02-01-2019, 12:33 PM
Have you run a compression test?
A reading of 375 is good. A compression of 325 will run the engine, but it will be weak and usually prone to smoke.
Airstreamer67 is offline
post #8 of 12 (permalink) Old 02-01-2019, 12:38 PM
Yeah I think a basic compression test is in order . The engine might be worn out .
How does the wiring harness look , the one that runs across the engine and attaches to the valve cover connections and all your sensors ?
post #9 of 12 (permalink) Old 02-01-2019, 02:25 PM Thread Starter
joserollin's Avatar
I try to get it done this weekend to see what my numbers are, but would compression make the truck hesitate though. When you punch it falls flat like nothing its on its face then slowly builds up power/boost through the RPMs.
post #10 of 12 (permalink) Old 02-01-2019, 11:52 PM
You could pull the fuel bowl and clean the inlet screen and see if that helps . Be prepared to replace hoses and O rings .
Search the site and you’ll find many rebuild articles and how to’s
Similar Threads
2004 f350 6.0 loss of power on hard Acceleration jerryragon 6.0L Power Stroke Technical Info 1 12-25-2018 08:06 PM
Trans delayed hard shift from 1-2 under hard acceleration OlBigRed7.3 7.3L Power Stroke Technical Info 4 08-13-2015 02:00 AM
top end noise under hard acceleration middlemanjw 7.3L Power Stroke Technical Info 5 01-13-2012 07:12 PM
truck falls on its face during hard acceleration halerazor 7.3L Power Stroke Technical Info 1 09-11-2011 04:22 AM
Strange issue during hard acceleration TripleE44 6.4L Power Stroke - Aftermarket & Performance 12 03-16-2011 01:22 AM
