7.3 low loping on start up - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By 97fordf250powerstroke
post #1 of 5 (permalink) Old 01-13-2019, 11:12 PM Thread Starter
hello psn! my 97 7.3 ford sometimes goes into this low loping sound. when you first start it, its fine, but after 30 seconds of idling it'll go into a rough lope. yes, she does have 350k+ miles on her, but she never used to ever do that. any help would be great!
97fordf250powerstroke is offline
post #2 of 5 (permalink) Old 01-17-2019, 06:07 AM
Re: 7.3 low loping on start up
You might wanna clean the SS screen on the inside drivers side about 1/3 way down inside the fuel filter canister. Drain a little fuel off, pull filter and with a flash lite, Q tips and a small mirror, clean inside the hole until you can see the stainless steel screen. If you’ve never done this there will probably be a fair amount of black sludge on the screen. This should help your idle.
Cheers,
j
Tan white tan 97 ECLB, D60 RSK SD springs front, airs bags rear, E4OD 4:10, intake, DP 4” exhaust
Red 97 F250 CC 3:55, D60 Air Locker front, 175/80s, T500, TW files, Tymar, SD I/C, 6.0 fan, E-air, E-Fuel, RSK, SD springs front/rear, 145 litre rear tank (now ZF-5
JCart is offline
post #3 of 5 (permalink) Old 01-21-2019, 04:00 PM Thread Starter
yeah, never done that before, actually never herd of the stainless steel screen in the canister, so ima go check that out.. thanks!
post #4 of 5 (permalink) Old 01-22-2019, 07:11 AM
Sure NP, this screen as I recall is on the return line back to the tank, keeping it clean will help make it run smoother. As your injector o rings wear and deteriorate this is where it gets caught up. You’ll also notice your fuel filter will become black, with worn injectors.
j
JCart is offline
post #5 of 5 (permalink) Old 01-23-2019, 11:09 PM Thread Starter
ahh definitely see what you mean. and yes you are correct, it is exactly where you said. still haven't checked if there is black, (didn't have time), but yes i see what you mean, and what could turn out to having black sludge in the fuel filters. You have helped me out a lot sir! thanks!
JCart likes this.
