cant get trans back on truck - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 27 (permalink) Old 03-22-2010, 08:45 PM Thread Starter
I have a 96 5 speed crew cab and can not get the trans mission back on after changing the clutch and fly wheel.
Is there any kind of trick to doing this?
Burning DIESEL.....Burning DINOSAUR Bones- J.R. Cash
96' Powerstroke CC Bone stock..... DIY intake, exhaust, and PHP 6 pos. soon. Hopefully
Jprejean is offline
post #2 of 27 (permalink) Old 03-22-2010, 10:31 PM
roughneck0913's Avatar
Re: cant get trans back on truck
are you sure the splines are the lined up? are you sure the new clutch disc slides over the input on the tranny other then that they can be a pain...
roughneck0913 is offline
post #3 of 27 (permalink) Old 03-22-2010, 10:51 PM
Nitro41's Avatar
i popped my dowel pins out and put them in the block side, not the transmision. that makes lining it up real easy.
me and my buddies through mine up there real easy. we also had a 2 post lift and a hydraulic trans jack
97 Single Cab F250 4x4 5 speed
Swapped D-60
Locked front and rear
160 sticks
Wildman Tunes
T500 HPOP
OFE clutch
Linex rockers
35" Toyo M/Ts
and a bunch more...
Nitro41 is offline
post #4 of 27 (permalink) Old 03-22-2010, 10:57 PM Thread Starter
i have a a trans jack but it's not hydro it mor eof a scissor type lift i did line the splines up and the hole on the tranny. still cant get it to go.........driving me crazy
Jprejean is offline
post #5 of 27 (permalink) Old 03-22-2010, 10:59 PM
Haters Gonna Hate
Fordfreak4life's Avatar
did u use the clutch plate centering tool, and did u replace your pilot bearing and throwout bearing, if u haven't replaced those 2 bearings i wouldn't put it back in yet, use your clutch alignment tool and get the plate centered and make sure u are going in at the same angle the crank is setting, put the trans in second gear so u can turn the output shaft and rotate the splines and slide it in there
Fordfreak4life is offline
post #6 of 27 (permalink) Old 03-22-2010, 11:03 PM
blue99sd's Avatar
If you put the trans in gear, you can turn the transfer case to slip the spline into the clutch.
99 PSD dually
4" lift 35' tire
4" exhaust to 6" Aussie's
K&n air filter
cc mod
Beans stage II 120hp injectors
Beans D66 turbo
ITP regulated return
updated ecm (2000 model)
reburned TS chip- 25,high idle,60,100,120,140hp
Dyno #'s 360hp and 965 ft lbs trq
blue99sd is offline
post #7 of 27 (permalink) Old 03-22-2010, 11:04 PM Thread Starter
yeah i noticed the engine is tilted backwards quite a bit. i dont have it in second. Of cousre i used the alignment tool it came with new everything so i did replace the bearings and the splines are all aligned
Jprejean is offline
post #8 of 27 (permalink) Old 03-22-2010, 11:05 PM Thread Starter
btw the way it is 2wd
Jprejean is offline
post #9 of 27 (permalink) Old 03-22-2010, 11:06 PM
Haters Gonna Hate
my buddy ran into this a couple weeks ago u may not be lined up just perfect with the pilot bearing, it takes a lil wiggling but if u get the front of the shaft in the pilot bearing where u can wiggle it and know for sure ur atleast started into the pilot bearing it will be much easier to get aligned, do u have it started into the splines on the clutch?
post #10 of 27 (permalink) Old 03-22-2010, 11:16 PM Thread Starter
i had gotten the tip of the input shaft into the pilot bearing but was unable to get the transmission to move any further. why i do not know i pulled it back out and lowered it and will be trying to get it in early tomorrow morning as i am leaving for class.
What is the best way to get the trans at an angle because my trans jack is flat.
Jprejean is offline
