Manifolds - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 01-06-2019, 12:27 AM Thread Starter
Manifolds
I have a 97 f350 7.3 the passenger side manifold had a big hole in it so I was able to get it off but the studs are still in the block. Of course they are in really bad shape. Any ideas on what the easiest way to get them out is??
Mpicklezz88 is offline
post #2 of 4 (permalink) Old 01-06-2019, 01:10 AM
Master BS'er
jamiesaun's Avatar
Re: Manifolds
Did they break off or are they regular studs?
If there is still enough stud left the easiest way will be to use two nuts as jam nuts. Put them both on and loosen one and tighten the other until they get real tight, then get a wrench on the bottom one and spin the stud out.
if they're really rusty I would soak them with penetrating oil, then get the stud red hot. Then spray more oil while it's hot, it'll suck the oil down in there. Then let it cool down to the point where you can touch it. They should spin right out after that.
Brother James
Ps...Im pretty frickin awesome!
jamiesaun is online now
post #3 of 4 (permalink) Old 01-06-2019, 05:28 AM
Project Shamu
Lt.Dan's Avatar
Re: Manifolds
Heat is your best friend, be careful.
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 378,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
1983 F150 SCSB Flareside, 302 w/ AOD Trans
2002 F450 SCFB, 7.3 PSD 2wd w/ 144,000 miles
SOLD
Lt.Dan is offline
post #4 of 4 (permalink) Old 01-10-2019, 12:03 AM
Re: Manifolds
Purchase a set of stud removal sockets for rounded bolt heads and studs. Use a quality penetrating fluid and heat, you might have to heat cycle I.e., heat up spray, let cool heat up again spray cool etc. Put on the appropriate socket and they should twist out. Upon install use new Ford stock bolts, quality anti seize paste and aftermarket gaskets. Note that the middle bolt hole on the exhaust manifold will be smaller diameter then the rest thats for lining up the manifold, install that one first.
Cheers,
j
Tan white tan 97 ECLB, D60 RSK SD springs front, airs bags rear, E4OD 4:10, intake, DP 4” exhaust
Red 97 F250 CC 3:55, D60 Air Locker front, 175/80s, T500, TW files, Tymar, SD I/C, 6.0 fan, E-air, E-Fuel, RSK, SD springs front/rear, 145 litre rear tank (now ZF-5
JCart is offline
