Please help going crazy - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 01-05-2019, 05:09 PM Thread Starter
OK I own a 1996 Ford F-250 7.3 my problem is that at low RPM‘s going up a hill maintaining semi low rpm’s under 2000 the truck chugs just about every time motor is under a little load it chugs high rpms seem fine I don’t know I’m new to the truck checked fuel pressure at low rpms it’s I think 80psi then floored the lowest I seen was around 45psi tacking little over 3000 rpms. Also replace valve cover gasket on passenger side because glow plug connector was burnt up but I had the problem before that I checked turbo, pulled injectors plugs ( with valve cover on) I don’t know if this is relevant But when I first got the truckAnd it did not even have enough power to run over a curb Oh turbo gauge floaters a little bit at high rpm’s it makes me feel like a injector ain’t working rightCan someone please help me I’m going insane
Joshuaoakes4793 is offline
post #2 of 2 (permalink) Old 01-08-2019, 08:56 PM
Re: Please help going crazy
You checked your fuel pressure under WOT...45 lbs should be good.
For low power, check the MAP hose, MAP sensor and make sure the turbo boots are on tight.
How many miles are on the truck?
you might wanna rewrite your issues...I had to read it several times and I am still not sure what is going on with the "chugs" maybe put in specific RPM readings...is it a manual shift and automatic transmission?
Can u do a buzz test to check your injectors?
1996 F350 Crewcab lb 2wd auto, tommylift, now over 451k, 355k 3/31/15
1991 F250 Xtracab lb 2wd auto, sold again! Driveline and chassis is under a '65 F350 cab
1965 F100 styleside, power brakes, front discs, 390 all the goodies
2015 F250 CCSB 2wd gasser auto
2008 Mustang WIP, warriors in pink, wife's
2009 Focus, son's
aussamdad is offline
