97 f350 7.3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 12-29-2018, 12:47 PM Thread Starter
Gametrap's Avatar
97 f350 7.3
I have a 97 f350 only has 70 thousand miles on it
Hard cold starts and when it starts if you drive it then it will idle rough and die about 10 minutes later
I can start it and let it warm up for a while and then it runs fine
Does anyone have any ideas
Gametrap is offline
post #2 of 2 (permalink) Old 12-29-2018, 01:42 PM
Moderator
Sbluke55's Avatar
Re: 97 f350 7.3
Hmm. I would start off by ohming the glow plugs and testing the gpr. After it sitting over night, check the hpop res to see if it had oil in it. Did you check your oil? How old is it?
01 f-250, Standard
Sbluke55 is offline
