Need help with some problems with my turn signals and hazards - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 12-26-2018, 11:15 PM Thread Starter
Alexhart787's Avatar
Hey all, I have a 97 f250 7.3 4wd automatic. My problem is I have no turn signals or hazards. I can manually use the turn signals like just moving the multifunction switch in the direction I want to turn but only when the brake pedal is pressed. I've replaced all the bulbs, checked the fuse and replaced both flasher relays. Also the hazard button has to stay on otherwise I have no turn signals or brake lights. And another thing I've noticed is that if I'm driving and i turn the hazards OFF my rpms increase about 300 rpm not sure what's causing that either. I'm at a loss to what the problem is. Any help would be greatly appreciated.
Alexhart787 is offline
post #2 of 3 (permalink) Old 12-27-2018, 12:01 AM
79jasper's Avatar
Re: Need help with some problems with my turn signals and hazards
I would replace/clean the multifunction switch.
79jasper is offline
post #3 of 3 (permalink) Old 12-28-2018, 04:05 AM Thread Starter
I just picked up a new switch from advance auto so I'll throw it in tomorrow and see how it goes, ill keep you posted. Thanks for the reply
