need new fuel pump, best way to go . - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 03-22-2010, 01:42 PM Thread Starter
Toyota Geek
ridiesel's Avatar
my fuel pump is looking like a leaker. so my question to you pros is what the route for me when i replace my fuel pump. i ran a quick search but didn't come up with much. just looking for companies and prices and where to buy.
-drew
1995 powerstroke
170000 miles with a couple leaks
1993 toyota pickup
12 inches of lift and counting.
lots of dents
ridiesel is offline
post #2 of 7 (permalink) Old 03-22-2010, 02:31 PM
oldbluef250's Avatar
Re: need new fuel pump, best way to go .
electric fuel
2003 F350 cclb 6.0
oldbluef250 is offline
post #3 of 7 (permalink) Old 03-22-2010, 02:39 PM Thread Starter
Toyota Geek
ridiesel's Avatar
is that the company that makes them or is it just the kind of fuel pump i want to go with. and do any of the vendors here sell these types of fuel pumps.
-drew
1995 powerstroke
1993 toyota pickup
lots of dents
ridiesel is offline
post #4 of 7 (permalink) Old 03-22-2010, 06:08 PM
If you just want to replace the mechanical pump, go to Autozone or Advance Auto or whoever your favorite parts store is...the mechanical pumps are supposedly all made by Carter, doesn't matter who rebrands them and sells them as their own.
Electric fuel refers to a complete replacement of the fuel pump/filter system...everything that's on the engine side of the tank selector valve. Most of us make our own, using a SD electric pump, a couple of filter bases and filters, and an aftermarket fuel pressure regulator, plus a few miscellaneous fittings. Mine cost less than $300.
Or you can buy the systems from Beans or Swamps, they're around a grand I believe.
'94 F250 supercab 4x4, original owner, 4.10LS, DIY elec fuel, Tymar air, Beans tunes on VA 4 position chip, Adrenaline HPOP, VDO boost/pyro/outside temp gauges, Ford digital AIC, DPPI downpipe, gutted EBPV, modded turbo ped, Con OFE, add-a-leafs front/rear, Monroe Reflex shocks, Milemarker 449SS hubs...coming soon: 6.0 IC...wish list: Stage 2's
nashvillebill is offline
post #5 of 7 (permalink) Old 03-22-2010, 07:05 PM
Ticking time bomb
fuel lab
I wonder what my sig and avatar will get changed to now!!
groomzybanshe is offline
post #6 of 7 (permalink) Old 03-23-2010, 03:07 AM
Dairy Mechanic
Magnum PD's Avatar
I got a mechanical pump if you want to just replace it and do the electric later.
96 Ford F-350 200 cc's, Electric fuel system, TS chip, 17 oil pump, Banks intercooler, 3" intake manifolds, SNOW Water-Meth system, South Bend DxD 3600, Banks brake, 4" stacks. Tuff country ladder bars.
IH RULES Not a 6.0 fan, engine out right now.
Magnum PD is offline
post #7 of 7 (permalink) Old 03-23-2010, 04:43 AM
Underfunded
moonshiner's Avatar
Send a message via AIM to moonshiner
You can do a basic electric system fairly inexpensive, and after yankin out my mechanical pump today... not super thrilled with the constuction, since the plunger part snaped off on removal.
Is it your mech pump thats leaking or the Fuel Pressure Regulator on the side of your fuel bowl? cause thats what it was on mine, and after 4 o-rings I called it quits an assembled a E-fuel system thats currently being put in
1996 F350: 4.10's Detroit Locked Front/Rear, Rampage Chip, SD/Racor E-Fuel, Adrenaline, 160cc's, Bell SS/66 Turbo, SD CAC, 315/75/16's Fierce M/Ts, 6" Lift, 6ft Traction Bars, 5" Stacks.
2007 Harley FXSTB: Bassani Prostreet Pipes, Terry Comp tuner, V&H Air Cleaner
2008 Honda Ridgeline RTX
2010 VW Jetta 2.5
SEMPER FI - USMC LT.
moonshiner is offline
