Disk Brake Conversion - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 12-15-2018, 06:51 PM Thread Starter
dsmessier's Avatar
Garage
Look for any ideas for a Disk Brake Conversion for a 1997 F350 4x4 while maintaining the same lug pattern as the front
David S Messier (US Navy Retired)
dsmessier is offline
post #2 of 3 (permalink) Old 12-15-2018, 07:26 PM
Re: Disk Brake Conversion
I did the Cadillac Eldorado disc brake conversion earlier this year. So far I’m pleased with it. I had intended to just grab a rear axle off a super duty and have a new lug pattern machined but I won the brake conversion in a raffle so that’s the route I took.
1995 Crewcab XLT 4x4 7.3, E4OD, 3.55, TS 6 chip, RiffRaff air filter.
Whoknows is offline
post #3 of 3 (permalink) Old 12-22-2018, 03:10 PM
m j
m j's Avatar
I am selling my 10.25 today that I put 10.5 brakes on.
uses e350 rotors
remove 10.25 backing plate mount
fab a mount that matches the 10.5 brakes mount
a little welding
a bunch of grinding on the parking brake pads to get them to clear the 10.25s much larger hubs.
done.
if I were to do it again I would start with e350 dana axle as a donor as the parking brake pads are already clearanced for the hubs.
I couldnt swap to them as they use a different style pivot, could be a year thing but I never investigated it too much
very easy swap
1997 F250 rclb 4x4,Comp910s,SRP1.1,Irate T4 s468,FullForce 350/200,efuel A1000 5/8" drawstraw,DI fuel fittings,D60f Detroit,Grizzly10.25,windowed 7.3 Oct 9/14
rebuild .010 riffraff cut pistons,swamps fire ring kit,Girdle,high-filled block,Manley rods,SBC dualdisc,ATI dampner,MorelLifters,MantonPushrods,ColtCam,
m j is offline
