P1272 high to low open on #2 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 12-14-2018, 07:28 PM Thread Starter
95 F250 2001 F450
Powerstrokebuff's Avatar
I was looking at a very old post on the p1272 code.
Looks like some were saying it is most likely electrical not hydro. I started running rough going down the road the other day. It is now intermittent. I did the buzz test and I get the code on #2 injector. When it's running bad you get a very quite buzz on #2, and when I run the test when it's running good I get the same strong buzz on all cylinders but still get the code. I have replaced the VC gasket/harness. Still get the code but is running smooth for now, could it be a bad injector or should i keep chasing the electrical, any body get this figured out? ideas sure would be appreciated Thanks
Powerstrokebuff is offline
post #2 of 2 (permalink) Old 12-14-2018, 09:13 PM
Moderator
Sbluke55's Avatar
Re: P1272 high to low open on #2
I already answered this in your other thread. I'm going to lock this one and if you can find the other and post there.
01 f-250, Standard
Sbluke55 is offline
Closed Thread
