1997 f250 7.3l with e4od - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 12-06-2018, 02:04 AM Thread Starter
mtnash99
mtnash99's Avatar
Hey everyone I have a 97 psd and I've been having a problem with it while driving. The truck idles just fine, and drives fine most of the time. Every once in a while I'll be driving and the rpm just like drops. It's not just the tac cuz I sure feel it especially if I'm building boost. I can't find any like chain of events where it does it. It's just randomly doing it.at first it was every once in awhile, like twice a month, but now I can be as often as a couple times a day and then sometimes it won't do it for a while and then it starts back up
1997 Ford F-250 7.3l Powerstroke
mtnash99 is offline
post #2 of 9 (permalink) Old 12-06-2018, 11:29 AM
Moderator
Sbluke55's Avatar
Re: 1997 f250 7.3l with e4od
I would start by changing the cps. Very common for it to go out. Use ford or international parts only.
01 f-250, Standard
Sbluke55 is offline
post #3 of 9 (permalink) Old 12-06-2018, 12:05 PM
CAT lover
Robertl211's Avatar
I'll second the CPS. Buddies truck did exactly this and I threw a CPS in it bam fixed.
96 F250 RCFB 4x4 7.3
96 f350 CCLB Dually ZF5, custom flatbed, Gregio Medio Lamborghini paint, 3" dp 4" MBRP exhaust
95 F250 RCLB 7.3 4x4 conversion with 5" Sky RSK, D60 front, 18" American Racing, 35" Nittos, DIY SD intercooler, Melling LPOP, DIY 6637, Baby Swamps with TS6 and Swamps tunes, boost pyro trans
05 F350 RCLB Dually SOLD
Robertl211 is offline
post #4 of 9 (permalink) Old 12-06-2018, 01:02 PM
Yup Classic cam position sensor on the way out. Go to dealership buy two, install one and keep the spare in the glove box. When you install itís a 10mm bolt, use a six sided socket, sometime bolt can be tight and you donít want to round the head. Upon install of this bolt do not cross thread as the front engine cover is aluminum that the bolt goes into. You do not want to cross thread this bolt, was down that path one time..... just take your time. If you cross thread this bolt it means pulling the front end off the truck to install a hellicoil and is a Royal PITA.... hahaha. Also I use a quality anti seize paste on the threads.
Cheers,
j
Tan white tan 97 ECLB, D60 RSK SD springs front, airs bags rear, E4OD 4:10, intake, DP 4Ē exhaust
Red 97 F250 CC 3:55, D60 Air Locker front, 175/80s, T500, TW files, Tymar, SD I/C, 6.0 fan, E-air, E-Fuel, RSK, SD springs front/rear, 145 litre rear tank (now ZF-5
JCart is offline
post #5 of 9 (permalink) Old 12-06-2018, 04:31 PM Thread Starter
mtnash99
mtnash99's Avatar
Okay awesome, l give it a shot later today and let you guys know. Thanks for the quick responses!
mtnash99 is offline
post #6 of 9 (permalink) Old 12-07-2018, 02:21 AM Thread Starter
mtnash99
mtnash99's Avatar
Well everyone, I got the sensor and went to take the old one off. Previous owner stripped the bolt. I've tried vise grips box wrenches etc. This thing is being a pos
mtnash99 is offline
post #7 of 9 (permalink) Old 12-07-2018, 06:50 AM Thread Starter
mtnash99
mtnash99's Avatar
Got it all done. Took 8 hrs. Thanks for everyone's help! I'll keep you guys updated on if it fixed the problem. And the old bolt was very stripped. Had to weld a wrench on it
mtnash99 is offline
post #8 of 9 (permalink) Old 12-07-2018, 01:32 PM
I hate suffering from some other guy's mistakes. At least you didn't have to do it on the side of an Interstate.
Hope it works!
Airstreamer67 is offline
post #9 of 9 (permalink) Old 12-07-2018, 11:27 PM Thread Starter
mtnash99
mtnash99's Avatar
No kidding! Thanks man
mtnash99 is offline
