1995 f350 brake slowly falling to floor - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 11-19-2018, 03:27 AM Thread Starter
I have a 1995 f350 and have been having break issues, when the truck is off the peddle is hard as a rock when i push it, but when i start it and the truck is running if i push the brake it will slowly fall to the floor i can pump the brake back up and its hard then falls back to the floor, I've bleed and rebleed all of the lines have no breaks in the lines and have replaced the booster with no luck, any help on this issue would be helpful the truck has 200k on it if that helps at all
Eric Barto is offline
post #2 of 11 (permalink) Old 11-19-2018, 09:15 AM
alleged moderator
tjctransport's Avatar
Re: 1995 f350 brake slowly falling to floor
could be a bad master cylinder, or a bad RABS valve if all the lines and wheel cylinders are good.
tom
tjctransport is offline
post #3 of 11 (permalink) Old 11-19-2018, 01:36 PM
Randy4614's Avatar
Seems to be a common problem with them. Have replaced my master cyl ,no better. Guess the next step will be the RASB valve. This problem is on my 93 dually
Randy4614 is offline
post #4 of 11 (permalink) Old 11-19-2018, 06:14 PM
Mine does this as well, I’m thinking this was a known issue but I can’t find where I saw that at. I went through 3 master cylinders and bypassed my RABS and it never went away.
1995 Crewcab XLT 4x4 7.3, E4OD, 3.55, TS 6 chip, RiffRaff air filter.
Whoknows is offline
post #5 of 11 (permalink) Old 11-20-2018, 02:13 AM
Randy4614's Avatar
I can't believe for how common this problem seems to be that no one has come up with a solution.
post #6 of 11 (permalink) Old 11-20-2018, 09:33 AM
alleged moderator
my solution was bypassing the RABS. the brakes have worked fine for 29 years now.
tom
post #7 of 11 (permalink) Old 11-21-2018, 03:28 AM
Project Shamu
Lt.Dan's Avatar
How did you go about that?
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 378,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
1983 F150 SCSB Flareside, 302 w/ AOD Trans
2002 F450 SCFB, 7.3 PSD 2wd w/ 144,000 miles
SOLD
Lt.Dan is offline
post #8 of 11 (permalink) Old 11-21-2018, 09:20 AM
alleged moderator
got a piece of brake line, removed the lines from the RABS valve, and put the new line in the valves place. then bled the rear brakes.
tom
post #9 of 11 (permalink) Old 11-22-2018, 02:04 PM
Many times when this issue comes up it is due to air in the system or the rear shoes are out of adjustment. Try bleeding the system and then checking the rear brake adjustment.
Airstreamer67 is offline
post #10 of 11 (permalink) Old 11-26-2018, 02:37 AM
csp
Symptoms are also found with an internal master cylinder leak, meaning the fluid is leaking around the seals that provide pressure when you push the pedal, but does not leave the master cylinder.
csp is offline
