maxi-fuse #13 blows - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 11-15-2018, 10:34 PM Thread Starter
maxi-fuse #13 blows
I have not cranked my f350 4x4 7.3L automatic tranny, turbo, in over 2 weeks.
Went to crank it and found maxi-fuse #13 blown, replaced, turned engine over, blew same fuse..
Question is, what does this fuse under the hood control, so I can get it running...
PS, had 2 days under 30 degrees, first day back in the 60's...
Thank you for your time and efforts...
Sam.
SMHodo is offline
post #2 of 2 (permalink) Old 11-15-2018, 11:18 PM
Bugman's Avatar
Re: maxi-fuse #13 blows
Are you sure that it is #13 and not #22?
If it is #22 unplug the fuel bowl heater on the filter housing, replace the fuse and all will be fine. There are thousands of trucks out there running without the heater.
https://www.thedieselstop.com/faq/94...j/stji1002.htm
Bugman is offline
