What in the world caused this? - PowerStrokeNation : Ford Powerstroke Diesel Forum
 3Likes
  • 2 Post By Sbluke55
  • 1 Post By Dustybumpers
post #1 of 10 (permalink) Old 11-04-2018, 05:05 PM Thread Starter
This might be the wrong forum but I am in process of converting my F-450 Powerstroke from a Utility to a dump truck and on the way from the welding shop to have them check out how to start the work after I had taken the Utility box off a strange thing happened.
Now I am driving a cab and chassis with over inflated rear dually's but going down the road all of a sudden it felt like I was driving over 6" speed bumps on the road, the truck was bouncing violently and pulled extremely hard to the left as I was bringing it to a stop.
I hobbled over to a parking lot and got out, expecting to see a disaster under the truck. I had actually looked back in the rear view mirror as I was bringing the bucking bronco to a halt and fully expected to see one of the rear wheels rolling down the road back there.
I looked underneath, everything looked fine, nothing dragging or loose so got back in hoping to nurse it down the road to a shop about 1/2 a mile away. Everything worked just fine, rode smooth, shifted through all 5 gears.
Got home first thing I checked was differential oil, it was to the top and looked clean.
What could be the cause? I am guessing something in the brakes broke loose and jammed up so am having a brake shop check all wheels, brakes. Truck is driving smooth, no noises but am spooked. If this were to happen at highway speed it would be a disaster. Any suggestions?
cantankerous is offline
post #2 of 10 (permalink) Old 11-04-2018, 05:24 PM
Administrator
Zmann's Avatar
Re: What in the world caused this?
hung caliper that released after the stop would be suspect for the hard left
the hopping IDK it may have been death wobble? was the steering wheel oscillating
obviously, the truck dynamics changed when you removed the utility bed weight this can effect handling
but the end result will put the weight back on ( dump bed and rams /etc ) so it may all return to normal
(other than the hard left )
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #3 of 10 (permalink) Old 11-04-2018, 06:24 PM Thread Starter
OK, never heard of the term "Death Wobble" so not sure what that means other than I was scared to death and can't remember if steering wheel was wig wagging since I was clutching it tightly.
Good thing I was only going around 30 mph when it happened.
Yes, the heavy box and ladder rack being removed made the rear end prone to bouncing since the tires are inflated to maximum and the new steel with the dump will bring things back to more stability
post #4 of 10 (permalink) Old 11-05-2018, 02:19 AM
Patrick Feeley's Avatar
I know my 94 dually would get really squirrelly with the rears at 85 psi and no load. This was always due to the tire jockeys neglecting my instructions to put only 60 in the tires. I would get home and air them down and all was good. Once you get more weight back on it it should get better. Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3Ē DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
post #5 of 10 (permalink) Old 11-14-2018, 03:15 AM
Kid with a dream
Truck>Sex's Avatar
Garage
One time I got a fat ass rock stuck in between the two tires on the left side of a dually rear and as soon as I got up to 10ish mph it felt like I was hopping down the section road. So I stopped and found the rock. Took a big hammer and some motivation to get it out. Sounds like just another crazy incident to me
Truck>Sex is offline
post #6 of 10 (permalink) Old 11-14-2018, 06:19 PM
don't play well w others
Dustybumpers's Avatar
Bobtailing in a tractor trailer is just like that
You never know when you hit a bad patch of road with a light rear/heavy front. Makes the rear try to pass the front. Normal just be careful
I'm sure Tom will be along to comment on this.
Charlie
"A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool."
Dustybumpers is offline
post #7 of 10 (permalink) Old 11-14-2018, 06:24 PM
Moderator
Sbluke55's Avatar
It might be a while, isnít Tom at the mall playing Santa right now?
Zmann and Dustybumpers like this.
01 f-250, Standard
Sbluke55 is offline
post #8 of 10 (permalink) Old 11-14-2018, 09:37 PM
I don't think so. after the "incident" with the pet store pets at the mall, pretty sure he's banned from the mall now.
Charlie
post #9 of 10 (permalink) Old 11-14-2018, 09:55 PM
alleged moderator
tjctransport's Avatar
been there, done that, and it sure wakes you up!
not yet, that gig don't start until next friday.
that was Timmy the petvert, and you damn well know it!!
tom
tjctransport is offline
post #10 of 10 (permalink) Old 11-14-2018, 10:01 PM
Timmy, Tommy.
spelling pretty close...….
I or o...…..
tjctransport likes this.
Charlie
