Trans/wiring issues - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 30 (permalink) Old 10-26-2018, 01:50 AM Thread Starter
Trans/wiring issues
Recently bought a 96 7.3l with 305xxx on it. Was told the transmission would not shift properly. Seller said he was told the valve body was bad. So I bought the truck because I have a spare transmission and we replaced the valve body. The truck will still only go 40 mph. We also found a dead short in the wiring. Could a speed sensor be causing this?
Rooster16 is offline
post #2 of 30 (permalink) Old 10-26-2018, 02:10 AM
Native Texan
masakimm's Avatar
Garage
Re: Trans/wiring issues
That year truck uses the same speed sensor as the dash so not likely exactly what is it doing is it not shifting out of second. I had a problem with my 97 e4od not shifting out of second. these trans had a problem with the 2-3 shift valve sticking so they made a steel replacement. Also could be a problem with the solenoid pack.
"Y'all have a wonderful"
"My name is Bob the guy floating in the lake with no arms and no legs"
TSGT Bob W Martin USAF 1948-2014
Upgrades:
masakimm is offline
post #3 of 30 (permalink) Old 10-26-2018, 07:01 PM Thread Starter
Yes not shifting out of second. Replaced the solenoid pack with the valve body. Could it be the torque converter?
post #4 of 30 (permalink) Old 10-26-2018, 07:10 PM
Native Texan
masakimm's Avatar
Garage
well like I said the 2-3 shift valve is a known problem. the torque converter won't prevent it from shifting.either something is wrong with the wiring to the solenoid pack which should set a code in the pcm or the valve is sticking. I fought with mine a lot till I put a steel shift valve in.
Upgrades:
masakimm is offline
post #5 of 30 (permalink) Old 10-27-2018, 12:02 AM Thread Starter
Solenoid pack came out of the good trans. Thought we could save time by just transferring everything over but trans might just be bad.
post #6 of 30 (permalink) Old 10-27-2018, 12:03 AM Thread Starter
Replaced the vss on the rear end today and the same stuff is going on so might just have to bite the bullet and replace the whole thing.
post #7 of 30 (permalink) Old 10-27-2018, 12:58 AM
Native Texan
masakimm's Avatar
Garage
My trans came out of a running driving truck did nothing to the 2-3 shift valve but it still started sticking. I would not condemn it till you looking into the shift valve if the trans was worn out it would try to shift and slip. it not shifting is exactly what mine would do. have you tried to have the codes read to see if there are any. Like I said check the wiring external to the trans going to the solenoid pack if the signal never gets to the pack then I cant shift.
Upgrades:
masakimm is offline
post #8 of 30 (permalink) Old 10-27-2018, 01:56 AM Thread Starter
Will do tomorrow thanks for the info. Will let you know what I find out.
Thanks again.
post #9 of 30 (permalink) Old 10-27-2018, 02:14 AM Thread Starter
Also found a plug on the transfer case that was broken. Not sure if that would cause it. Tried plugging it in and still nothing. Will check voltage on it tomorrow along with the other plug going into the solenoid pack. What should the voltage read or how do you check for a bad plug?
post #10 of 30 (permalink) Old 10-29-2018, 06:56 PM Thread Starter
Will a wiring harness from same year of truck work that is a gas engine or diesel engine only?
