Very little boost,running bad and cut off? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 03-21-2010, 04:20 AM Thread Starter
Got in my truck this morning and drove to the gas station to get some diesel,ran fine one the way there,when i cranked it up to leave and pulled out and it had no power and it would barely make 5psi of boost and would go no higher. The more throttle u gave it the worse it would want to run,after driving it for a few miles it started to run better and started making boost again but it was in and out and would run bad,did the same thing all day and i was coming home it started runnig real bad and just cut off and would not crank,tried it about 30min later and cranked up,but still runs the same. Anyone got any thoughts on what is wrong? Thanks
fastmust88 is offline
post #2 of 10 (permalink) Old 03-21-2010, 04:37 AM
Re: Very little boost,running bad and cut off?
when was the last time you changed your fuel filter? have you cleaned the screen going to the fpr?
02 f250
countryboyrob is offline
post #3 of 10 (permalink) Old 03-21-2010, 05:25 AM
mallardslayer07's Avatar
Check it for codes? What codes if any? CEL? IPR? IPC?
Death Row Diesel Inmate #22
2001 F-250 Platinum Edition 6" ProComp XM Lift with 325 Nitto Terra Grapplers on 18" Diamo Karat wheels.
Intake and Exhuast.
SOLD: 97 F-250 4X4 with Injectors, Intake, Exhaust, butterfly delete, 6 pos TS custom tuning, Dana 60 swap.
mallardslayer07 is offline
post #4 of 10 (permalink) Old 03-21-2010, 03:02 PM Thread Starter
I havnt checked for any codes yet but its weird that no lights came on.
post #5 of 10 (permalink) Old 03-21-2010, 03:23 PM
fwiw I didnt get a code when my truck did the same thing, its was a clogged screen for the FPR
02 f250
post #6 of 10 (permalink) Old 03-21-2010, 05:09 PM Thread Starter
Im fixn to get out and check that now.
post #7 of 10 (permalink) Old 03-21-2010, 08:13 PM Thread Starter
I checked the screen and the fuel filter look fine. It runs good and idles fine just wont make any boost,it will go to about 5psi and thats it,try to get on the gas any harder and it will just bog down.
post #8 of 10 (permalink) Old 03-21-2010, 08:18 PM
what did you use to check the screen? I thought it was fine too til someone said to use a q-tip.
post #9 of 10 (permalink) Old 03-21-2010, 09:58 PM Thread Starter
I just looked at it but it was clean from what i can tell. i have seen it dirty before and not doin what it is doin now.
post #10 of 10 (permalink) Old 03-21-2010, 10:01 PM Thread Starter
Its just weird,it will rev just fine and runs smooth but when u drive it,u can just not get on the throttle real hard and it will not make over 5psi and u can just put it to the floor and it will not go . i was wonderin if there was any way the Map sensor was bad or somethn,it asks like the vaccum hose if off .
