97 f250 skipping and knocking - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 10-25-2018, 12:08 AM Thread Starter
Reitz's Avatar
https://youtu.be/EBvnflugPg8 so my truck is pretty much doing the exact same thing as this truck
Reitz is offline
post #2 of 10 (permalink) Old 10-25-2018, 02:57 AM
Patrick Feeley's Avatar
Re: 97 f250 skipping and knocking
Any CEL? Need more info on the truck such as recent maintenance performed? Any mods like a chip? Check the Injection Pressure Regulator (IPR) solenoid nut to make sure it is there and snug. Oil level? Fuel pressure? Oil in he ICP connection? Cheers!
Patrick Feeley is offline
post #3 of 10 (permalink) Old 10-25-2018, 11:50 PM Thread Starter
Reitz's Avatar
no CEL. It’s honestly been doing the studdering and knocking since last February after I fried an idm. So I replaced the idm and it started. I’ve got PHP hydra chip with custom tunes for my baby swamp injectors. I’ve looked at the IPR and it was tight. I’ve changed the ICP with a motorcraft one. Oil level is good. Recently did an oil change. Fuel pressure is 60 psi idling and 30 when matted. I’ve already replaced the fuel pump recently. No oil in ICP sensor. I’ve got a swamps high voltage high frequency idm. I don’t think is a fuel supply problem. I changed out all my injectors because I thought that might be the problem. But it wasn’t, so everything under the valve cover is pretty well new. Including UVC harness. Also has a fluttering idle. It just feels like the fuel is just getting cut off for a second
Reitz is offline
post #4 of 10 (permalink) Old 10-26-2018, 03:21 PM
97obs_stroker's Avatar
Have you tried disconnecting the chip
97obs_stroker is offline
post #5 of 10 (permalink) Old 10-26-2018, 06:31 PM Thread Starter
Reitz's Avatar
yes. As well as going back to the factory idm
Reitz is offline
post #6 of 10 (permalink) Old 10-26-2018, 09:56 PM
Could have caught an injector harness when putting the valve cover back on.
post #7 of 10 (permalink) Old 10-26-2018, 09:57 PM
post #8 of 10 (permalink) Old 10-26-2018, 11:21 PM Thread Starter
Reitz's Avatar
I don’t believe this is the problem because it happened before I did anything with the UVC
Reitz is offline
post #9 of 10 (permalink) Old 10-27-2018, 01:11 PM
Maybe the idm isn't the only thing you fried. Do a contibution test buzz test see what is failing. Then back probe your wires to injectors from idm and see which one is missing continuity
post #10 of 10 (permalink) Old 10-27-2018, 03:49 PM
I would check the wiring per the procedure in this link just to rule that part out: GB Remanufacturing - Tech Bulletin #103
Cheers!
