I Want To Check Compression - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 10-22-2018, 07:55 PM Thread Starter
Diabolic1's Avatar
Is there a tester kit sold that fits properly without having to build my own whips from grease gun parts? Is there a kit specifically for the 7.3?
1997 CCSB, 7.3/E4OD
KC TP38R, CNC Fab Bellowed Up-Pipes, Full Force Stg 1 injectors, 3" DP, 4" exhaust, CNC Fab HPOP, Mark F E-Fuel, 7.3 Intercooler, 1.0 Exhaust Housing, TS Chip, remote coolant filter, and VB.
Diabolic1 is offline
post #2 of 2 (permalink) Old 10-23-2018, 12:56 AM
Patrick Feeley's Avatar
Re: I Want To Check Compression
Here's the adapter part of it so you don't need to remove the rockers:
Then you just need the gauge part to go with it:
The links are really just examples and could probably be found at lower prices. Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3Ē DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
