Ipr missing nut and spacer - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 10-21-2018, 11:34 PM Thread Starter
97obs_stroker's Avatar
Ive never had to tear into anything with the hpop just was looking around in there and seen the spacer and nut on the ipr are mia. What can i use to replace them? Going to remove ff housing and see if its down there somewhere.
97obs_stroker is offline
post #2 of 3 (permalink) Old 10-22-2018, 02:35 AM
Patrick Feeley's Avatar
Re: Ipr missing nut and spacer
They are probably down in the "valley of death", but if you can't find them, the parts would be in the IPR Reseal kit. Cheers!
Patrick Feeley is offline
post #3 of 3 (permalink) Old 10-26-2018, 03:16 PM Thread Starter
Found it burried under years of dirt and oil.
