Idle Drops Low When Trans Put In Gear - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 1 (permalink) Old 10-18-2018, 03:22 PM Thread Starter
Engine idle speed will drop very low when I put the trans in drive but then recovers to normal speed within 5 seconds or so. It seems to be worse when the air temp is cold and the engine actually died once earlier this year. Been doing this for a couple of years but I only drive the truck several times a month, but seems to be getting worse lately.
Also replaced injectors a couple months ago along with new ICP, CPS, and rebuild IPR. The problem seems worse now but I can't really attribute that to any work I did necessarily, maybe just more time passing. I was thinking possible trans/torque converter issue but it doesn't lurch forward at all even with no brake pressure. I would think it would?
Have access to AutoEnginuity but haven't had the time yet to do any diagnostics. Just seeing if anyone has seen something similar.
Thanks!
1997 F-250 HD 4x4/OR SC LB XLT PSD E4OD 3.55LS, TDE1, Baby Swamps (150/146/A), BTS Trans, BTS programming, Autometer Pyro, Trans Temp and Boost in Rockin' S Pod, Tymar style intake, 6.0 Intercooler, Tru-Cool Max tranny cooler, Warn Premium Hubs, Shimmed FPR, Gutted EBPV, Super Duty 3" DP, 4" Exhaust
TJanak is offline
