Racheting axle noise - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 03-20-2010, 11:53 PM Thread Starter
Underfunded
moonshiner's Avatar
Send a message via AIM to moonshiner
Have a 91 dana 60 kingpin, the bearings from the knuckle outward have all been replaced and properly greased with marine grade grease.
My axle is making a noise similiar to a rachet... Am i correct to assume my ujoint on my stub shaft is shot?
Also whats the best way to make my friggen brakes quit squeakin!! tried all of the auto-stores chemical wonders...
1996 F350: 4.10's Detroit Locked Front/Rear, Rampage Chip, SD/Racor E-Fuel, Adrenaline, 160cc's, Bell SS/66 Turbo, SD CAC, 315/75/16's Fierce M/Ts, 6" Lift, 6ft Traction Bars, 5" Stacks.
2007 Harley FXSTB: Bassani Prostreet Pipes, Terry Comp tuner, V&H Air Cleaner
2008 Honda Ridgeline RTX
2010 VW Jetta 2.5
SEMPER FI - USMC LT.
moonshiner is offline
post #2 of 3 (permalink) Old 03-21-2010, 12:18 AM
Re: Racheting axle noise
All that crap they sell just makes it worse. Without knowing what kind of pads you have I'd say to lube the sliders and sand the pads a bit. If that doesn't work then a brake job with turning the rotors will.
Not sure about the axle. Is it a locker? My back one sounds like that sometimes if I'm turning on dry pavement. It's a detroit locker though.
rrranch is offline
post #3 of 3 (permalink) Old 03-21-2010, 02:40 AM Thread Starter
Underfunded
moonshiner's Avatar
I have a locker upfront, but i have manual hubs so its not the locker, the rachetin noise isnt like that of the locker, nor does it feel like the locker. I know I blew the same lock-out hub that the noise is coming from, however I replaced that hub, and the noise still exists. I have done some research on the d60 and when they break a hub, they sometimes ruin a ujoint, but id like more opinions before I drop $120 for a set of ujoints...
2010 VW Jetta 2.5
