No horn or cruise - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 10-04-2018, 04:26 PM Thread Starter
No horn or cruise
For some reason I do not have a horn or cruise on my 1994 F250. I do not have a clockspring, as I do not have an airbag. Under my steering wheel I have the three pins, from my understanding, one is ground, one is signal, and one is power. I have the ground, middle one seems to be signal, but I do not have any power to the third one. I can't figure out where the fuse is for the horn/cruise. I do have horn when I jumper the pins for the relay.
Any ideas would be appreciated
Thanks!
fredws is offline
post #2 of 10 (permalink) Old 10-04-2018, 10:27 PM
79jasper's Avatar
Re: No horn or cruise
Clock spring has nothing to do with the airbag.
Sent from my SAMSUNG-SM-G930A using Tapatalk
79jasper is offline
post #3 of 10 (permalink) Old 10-04-2018, 10:57 PM Thread Starter
My understanding was that the pickups without the airbag do not have a clockspring, I could be wrong on that, either way, mine does not have a clockspring. That being said, I traced the wires down the column to the plug at the base of the steering column, and I do not have power at that point for some reason.
fredws is offline
post #4 of 10 (permalink) Old 10-04-2018, 11:25 PM
Native Texan
masakimm's Avatar
Garage
Well the switches for the horn are ground based. and iirc the cruise also works off ground with varying resistance.
"Y'all have a wonderful"
"My name is Bob the guy floating in the lake with no arms and no legs"
TSGT Bob W Martin USAF 1948-2014
Upgrades:
masakimm is offline
post #5 of 10 (permalink) Old 10-05-2018, 02:24 AM
79jasper's Avatar
That could be your problem then.
Correct. Had to refresh my memory.
79jasper is offline
post #6 of 10 (permalink) Old 10-05-2018, 02:56 PM Thread Starter
Okay, so you are saying that I shouldn't have power to any of the three pins at the steering wheel? I know that one is ground, pretty sure the middle one is for the cruise, which would leave the last one for the horn. So I should be able to jumper the first and last pins and have the horn go off, right?
Mine does not have a clockspring, it has three pins that are spring loaded, that ride on three different rings on the back of the steering wheel.
fredws is offline
post #7 of 10 (permalink) Old 10-05-2018, 06:51 PM
Native Texan
masakimm's Avatar
Garage
Yap that is correct. most of the obs fords were like that.
Upgrades:
masakimm is offline
post #8 of 10 (permalink) Old 10-05-2018, 07:16 PM
79jasper's Avatar
Weird. Even my 94 had a clockspring. Lol
Is that a non-tilt wheel?
79jasper is offline
post #9 of 10 (permalink) Old 10-05-2018, 07:43 PM
Native Texan
masakimm's Avatar
Garage
the only ones from that era that had clock springs also had airbags. I have replace and rebuilt many and very rarely see clock springs in the trucks.
Upgrades:
masakimm is offline
post #10 of 10 (permalink) Old 10-05-2018, 09:27 PM Thread Starter
Yes, it has a tilt wheel.
So, any ideas on where to look for a solution?
Thanks guys!
fredws is offline
