Would a loose tranny pan cause tranny to go into "limp mode"? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 10-01-2018, 03:58 PM Thread Starter
Hey guys,
I noticed a spot under my truck when my truck was at an incline, after getting under there I noticed drips of tranny fluid and slow steady drip of some kind of frame bar below the tranny... I went to clean the drips of and discovered that the bolts towards the rear were so loose I could have unscrewed them by hand, the other bolts were loose too but not as bad. Prior to this the reason why I parked it was because the O/D light would flash on hot days and cause a hard shift. Would the loose pan be enough to cause the tranny to go into limp mode??? I would scan for codes but I cannot find a scanner from ford that will fit my truck
Thanks!
N8THAN1033 is offline
post #2 of 2 (permalink) Old 10-01-2018, 04:59 PM
sooty
Re: Would a loose tranny pan cause tranny to go into "limp mode"?
Low fluid could cause that so, I guess indirectly, the loose pan caused a shift issue lol
sooty is offline
