E4od slipping in reverse - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 10-01-2018, 06:28 AM Thread Starter
97 4x4 auto slips in reverse. All forward gears are fine. If you try to back up in reverse it barely moves if on an incline. If you put the transfer case in low it helps. What could be causing this?
1997 cc lb 4x4 5 speed tymar 4 inch diamond eye straight pipe, 20 inch Eagle Alloy polished wheels,power hungry 6 pos tuned for stage 1's,idm mod,8000k H.I.D's. 4'' icon front super duty springs with sky 5'' rsk. rear 6'' icons for super duty. bilstien shocks. ebay special grill.
cams-76 is offline
post #2 of 6 (permalink) Old 10-02-2018, 02:49 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: E4od slipping in reverse
A burned up low/reverse clutch.
Mark
Mark Kovalsky is offline
post #3 of 6 (permalink) Old 10-02-2018, 05:34 PM Thread Starter
How much of an ordeal is it to change that out?
cams-76 is offline
post #4 of 6 (permalink) Old 10-02-2018, 08:24 PM
Native Texan
masakimm's Avatar
Garage
Plan on a full rebuild if u are going that far in maybe some upgrades while in there.
"Y'all have a wonderful"
"My name is Bob the guy floating in the lake with no arms and no legs"
TSGT Bob W Martin USAF 1948-2014
Upgrades:
masakimm is offline
post #5 of 6 (permalink) Old 10-03-2018, 03:34 AM
Pull the trans out and rebuild it or replace it.
Mark
post #6 of 6 (permalink) Old 10-03-2018, 06:41 AM Thread Starter
I have been reading up and seeing a few things talking about checking the pressure. How is the pressure checked?
cams-76 is offline
